Chris Kelly wrote: Tue Jun 25, 2024 7:59 am Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.05
Serial number: TKDL001706WL
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: Pioneer RS8F01
Firmware version: ID58
At least I still have my LG drives for backup.
LibreDrive for Pioneer drives
Chris Kelly
Is there a way to flash this back to the latest firmware that supports Libredrive whether 1.03 or 1.02?
No.Chris Kelly wrote: Sun Aug 04, 2024 12:53 pm Is there a way to flash this back to the latest firmware that supports Libredrive whether 1.03 or 1.02?Chris Kelly wrote: Tue Jun 25, 2024 7:59 am Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Revision: 1.05
Chris Kelly
Besides having my LGs for 4K UHD Blu-rays, I still have this Pioneer for ripping DVDs and HD Blu-rays. So it's not like I can't use my Pioneer at all. And maybe after years, someone will either come up with a way to flash it backwards or add Libredrive to it with newer firmware so I can use it for 4K UHD Blu-rays again..Coopervid wrote: Sun Aug 04, 2024 1:28 pmNo.Chris Kelly wrote: Sun Aug 04, 2024 12:53 pm Is there a way to flash this back to the latest firmware that supports Libredrive whether 1.03 or 1.02?Chris Kelly wrote: Tue Jun 25, 2024 7:59 am Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Revision: 1.05
viewtopic.php?f=19&t=30383
We are waiting since then but it looks like Pioneer did a very good job regarding the encryption of the firmware.
So, was looking at a new blu-ray drive to start ripping my UHD collection, when I saw that my drive might have that ability with a BIOS flash, maybe? I know it's BDXL compatible, but definitely came out before 2016.
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: [redacted]
Firmware date: 2017-12-21
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.50/ID60
I have a auto flasher for it.Xorshasia wrote: Sun Aug 18, 2024 2:25 am So, was looking at a new blu-ray drive to start ripping my UHD collection, when I saw that my drive might have that ability with a BIOS flash, maybe? I know it's BDXL compatible, but definitely came out before 2016.
Revision: 1.50
Email me your drive info see below
artfuldodgerosu
I ran into this. Not sure how to proceed.
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL025772WL
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
Revision: 1.02
I have a auto flasher for it.artfuldodgerosu wrote: Sat Aug 24, 2024 12:18 am I ran into this. Not sure how to proceed.
Revision: 1.02
I'm stuck
Product: BD-RW BDR-XS07U
Revision: 1.00
Firmware date: 2019-01-07
Firmware version: ID69
Revision: 1.00
email me for a flasher for it
My new BD-RW BDR-X13U has just been delivered to me. And this is what I see in MakeMKV:
Does it take long for it to be "enabled" or should I return this one and try to get a older one somewhere else?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-X13U
Revision: 1.03
Serienummer: [redacted]
Firmware-Datum: 2022-12-12
Firmware version: ID29
Disk-Informationen
Label: UHD_WWY
Zeitstempel: 2020-09-03 09:46:27
Schutz: AACS2.0/C v72
Datenkapazität: 58.48 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80-
Well, we've been waiting a year and a half so far and still no closer to drive's with firmware after Nov 2022 being enabled....Olini wrote: Sat Aug 31, 2024 2:27 pm My new BD-RW BDR-X13U has just been delivered to me. And this is what I see in MakeMKV:
Does it take long for it to be "enabled" or should I return this one and try to get a older one somewhere else?Code: Select all
Laufwerksinformation OS-Gerätename: \Device\CdRom0 Aktuelles Profil: BD-ROM Produzent: PIONEER Produkt: BD-RW BDR-X13U Revision: 1.03 Serienummer: [redacted] Firmware-Datum: 2022-12-12 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9401 Firmware version: ID29 Disk-Informationen Label: UHD_WWY Zeitstempel: 2020-09-03 09:46:27 Schutz: AACS2.0/C v72 Datenkapazität: 58.48 Gb Disk-Typ: BD-ROM UHD Anzahl der Layer: 2 Markierungen der Bus-Verschlüsselung: 80
Pretty much all drives from retail stores will have firmware that is too new. The only way to get a compatible Pioneer drive is to purchase from a seller on this forum.
I received a BDR-S13E-X with firmware before December 2022 (MFD 08-2022) and I definitely don't want to lose it.
Is there a risk that a firmware update will be installed automatically by Windows or driver updates, or is the only rule: Never touch a firmware update, and everything will be fine?
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-S13JX
Revision: 1.02
Serienummer: -
Firmware-Datum: 2022-02-10
Highest AACS version: 28
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID72
Keine Disk eingelegt
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.02
Serienummer: -
It won't auto update your finebackdash wrote: Tue Sep 03, 2024 9:39 am I received a BDR-S13E-X with firmware before December 2022 (MFD 08-2022) and I definitely don't want to lose it.
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.02
Serienummer: -
Just don't download the updater
Got my hands on an old ASUS (Pioneer) drive and what I've gathered here is that I might be able to open LibreDrive / UHD on this drive? Any instructions appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ---
Firmware date: 2023-04-20
Firmware version: ID26
Manufacturer: ASUS
Revision: E102
Serial number: ---
