LibreDrive for Pioneer drives
Chris Kelly
Post by Chris Kelly »
Is there a way to flash this back to the latest firmware that supports Libredrive whether 1.03 or 1.02?
Chris Kelly wrote: Tue Jun 25, 2024 7:59 am Will support for Pioneer drives with upgraded firmware eventually be supported? Unaware I'd lose compatibility, I upgraded my BDR-212UBK from 1.02 to:
Manufacturer: PIONEER
Product: BD-RW BDR-212U
Revision: 1.05
Serial number: TKDL001706WL
Firmware date: 2023-08-01
Highest AACS version: 77
Drive platform: Pioneer RS8F01
Firmware version: ID58
At least I still have my LG drives for backup.
Chris Kelly wrote: Sun Aug 04, 2024 12:53 pm Is there a way to flash this back to the latest firmware that supports Libredrive whether 1.03 or 1.02?
Revision: 1.05
No.
Chris Kelly
Coopervid wrote: Sun Aug 04, 2024 1:28 pm
Revision: 1.05
No.
Besides having my LGs for 4K UHD Blu-rays, I still have this Pioneer for ripping DVDs and HD Blu-rays. So it's not like I can't use my Pioneer at all. And maybe after years, someone will either come up with a way to flash it backwards or add Libredrive to it with newer firmware so I can use it for 4K UHD Blu-rays again..
viewtopic.php?f=19&t=30383
We are waiting since then but it looks like Pioneer did a very good job regarding the encryption of the firmware.
Xorshasia
Post by Xorshasia »
So, was looking at a new blu-ray drive to start ripping my UHD collection, when I saw that my drive might have that ability with a BIOS flash, maybe? I know it's BDXL compatible, but definitely came out before 2016.
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: [redacted]
Firmware date: 2017-12-21
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.50/ID60
Xorshasia wrote: Sun Aug 18, 2024 2:25 am So, was looking at a new blu-ray drive to start ripping my UHD collection, when I saw that my drive might have that ability with a BIOS flash, maybe? I know it's BDXL compatible, but definitely came out before 2016.
Revision: 1.50
I have a auto flasher for it.
Email me your drive info see below
artfuldodgerosu
Post by artfuldodgerosu »
I ran into this. Not sure how to proceed.
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DCDL025772WL
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
artfuldodgerosu wrote: Sat Aug 24, 2024 12:18 am I ran into this. Not sure how to proceed.
Revision: 1.02
twsmit
Post by twsmit »
I'm stuck
Product: BD-RW BDR-XS07U
Revision: 1.00
Firmware date: 2019-01-07
Firmware version: ID69
email me for a flasher for it
Olini
Post by Olini »
My new BD-RW BDR-X13U has just been delivered to me. And this is what I see in MakeMKV:
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-X13U
Revision: 1.03
Serienummer: [redacted]
Firmware-Datum: 2022-12-12
Firmware version: ID29
Disk-Informationen
Label: UHD_WWY
Zeitstempel: 2020-09-03 09:46:27
Schutz: AACS2.0/C v72
Datenkapazität: 58.48 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 2
Markierungen der Bus-Verschlüsselung: 80
Does it take long for it to be "enabled" or should I return this one and try to get a older one somewhere else?
Olini wrote: Sat Aug 31, 2024 2:27 pm My new BD-RW BDR-X13U has just been delivered to me. And this is what I see in MakeMKV:
Produzent: PIONEER
Revision: 1.03
Disk-Informationen
Label: UHD_WWY
Anzahl der Layer: 2
Well, we've been waiting a year and a half so far and still no closer to drive's with firmware after Nov 2022 being enabled....
Pretty much all drives from retail stores will have firmware that is too new. The only way to get a compatible Pioneer drive is to purchase from a seller on this forum.
backdash
Post by backdash »
I received a BDR-S13E-X with firmware before December 2022 (MFD 08-2022) and I definitely don't want to lose it.
Is there a risk that a firmware update will be installed automatically by Windows or driver updates, or is the only rule: Never touch a firmware update, and everything will be fine?
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-S13JX
Revision: 1.02
Serienummer: -
Firmware-Datum: 2022-02-10
Highest AACS version: 28
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID72
Keine Disk eingelegt
backdash wrote: Tue Sep 03, 2024 9:39 am I received a BDR-S13E-X with firmware before December 2022 (MFD 08-2022) and I definitely don't want to lose it.
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.02
Serienummer: -
It won't auto update your fine
Just don't download the updater
MC777
Post by MC777 »
Got my hands on an old ASUS (Pioneer) drive and what I've gathered here is that I might be able to open LibreDrive / UHD on this drive? Any instructions appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ---
Firmware date: 2023-04-20
Firmware version: ID26
