Vaako
Re: Pioneer firmware update February 2023
Post by Vaako » Fri Aug 02, 2024 10:52 pm
Do you happen to know if this drive has an flash chip ?
Than it would be possible to flash (downgrade) firmware before 12/2022.
Tomorow I will check the drive internaly if I can find some kind of flash chip.
Post by Coopervid » Sat Aug 03, 2024 9:02 am
Vaako wrote: Fri Aug 02, 2024 10:52 pm Do you happen to know if this drive has an flash chip ?
Read your PM.
Vaako
Post by Vaako » Sun Aug 04, 2024 12:15 am
I have the firmwares from version 1.03 to 1.05 (versions 1.01 and 1.02 I could not find them)
Which one do I have to get installed that is before 12/2022 ?
BDR-212EBK / ULBK (BDR-2212)
ver.	change point
1.05	Added a new function "Fragile disc mode for music CD" Improved operational stability
1.04	Improvement of the playback operation with specific media
1.03	Improvement of the playback operation with specific media
1.02	Improvement of the playback operation with specific media
1.01	Support New BD-R TL media(4x Writing : RiTEK) Improvement of the operational stability when BD-R SL 16x speed recording.
Improvement of the operational stability when recording CD, DVD, BD.
Post by Coopervid » Sun Aug 04, 2024 10:04 am
Vaako wrote: Sun Aug 04, 2024 12:15 am I have the firmwares from version 1.03 to 1.05 (versions 1.01 and 1.02 I could not find them)
ver.	change point
You need a drive that is lower/ equal 1.02. If the firmware is newer, it will be encrypted and older firmwares can't be flashed to the drive.
Vaako
Post by Vaako » Mon Aug 05, 2024 10:07 pm
Does someone have this firmware 1.02 for the BDR-212 because I can not find it.
Update: nevermind I have found the file "BDR-212EBK_UBK_FW102EU.exe"
Now I got to figure out how to extract firmware from the executable and use a DOS flasher to force the flash.
Any advice/recommendations on this are very welcome !
Post by MartyMcNuts » Mon Aug 05, 2024 10:33 pm
Vaako wrote: Mon Aug 05, 2024 10:07 pm Does someone have this firmware 1.02 for the BDR-212 because I can not find it.
You can't!
Killertamagotchi
Post by Killertamagotchi » Tue Aug 06, 2024 6:57 pm
I guess I also have the problem that you can no longer make it UHD compatible?
Laufwerksinformation
OS-Gerätename: E:
Produzent: PIONEER
Produkt: BD-RW BDR-213M
Revision: 1.04
Serienummer: *****************
Firmware-Datum: 2022-12-12
Highest AACS version: 77
Drive platform: Pioneer RS9200
Firmware version: ID56
Post by Coopervid » Tue Aug 06, 2024 8:53 pm
Killertamagotchi wrote: Tue Aug 06, 2024 6:57 pm I guess I also have the problem that you can no longer make it UHD compatible?
OS-Gerätename: E:
Produzent: PIONEER
Revision: 1.04
Unfortunately you are correct. Not possible.
Killertamagotchi
Post by Killertamagotchi » Tue Aug 06, 2024 9:09 pm
hmm at least I can send it back to Amazon
Post by Coopervid » Tue Aug 06, 2024 10:13 pm
Killertamagotchi wrote: Tue Aug 06, 2024 9:09 pm hmm at least I can send it back to Amazon
Let us know your country of residence for new options.
Killertamagotchi
Post by Killertamagotchi » Tue Aug 06, 2024 10:44 pm
Coopervid wrote: Tue Aug 06, 2024 10:13 pm
Its Germany
Post by Coopervid » Tue Aug 06, 2024 10:48 pm
Killertamagotchi wrote: Tue Aug 06, 2024 10:44 pm
Its Germany
PM sent.
Rurido
Post by Rurido » Wed Aug 07, 2024 2:57 pm
Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Here's the info from MakeMKV:
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: ~
Firmware-Datum: 2017-04-18
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.10/ID22
Keine Disk eingelegt
Any help is much appreciated :)
Post by Coopervid » Wed Aug 07, 2024 4:26 pm
Rurido wrote: Wed Aug 07, 2024 2:57 pm Hi, I've recently discovered that I can't archive UHD disks. But I've read that this can be fixed with a firmware update. Unfortunately the guide I found here (viewtopic.php?p=74718) doesn't mention my drive platform "RS8510". Any options for my drive (https://www.asus.com/de/motherboards-co ... sbw06d2xu/)? It's an Pioneer drive (BDR-UD03ASW) inside an ASUS case, which I know because I already needed to open it up for some repairs. Which firmware do I need/where can I download it? If I understood it right, the flashing of the fw should be as easy as altering and running the makemkvcon64 command from the guide mentioned above?
Produzent: ASUS
Revision: 1.10
Serienummer: ~
PM sent.
Rurido
Post by Rurido » Wed Aug 07, 2024 10:06 pm
It worked, thanks a bunch! Though one question, the read speed seems to be quite low for UHD disks (around 0.2x-1.3x), is this normal?
