Rororororo
Post by Rororororo »
some combination in the new MODE.I (1) in 3.0.0/3.0.1 seems not to work like "DF", the section with options is a bit confusing and could be a bit more readable, also what are valves v and 7?
*You can select more than one value(except: e/m/p/s/7/v) but no space between values: EG: 569r4 (default= Exit)
L5=5/L6=6/L9=9/Resync=R or D/SC_Flag=F/RemCMV4=4 - /PLOT=P/CheckSync=S/Read=E/Metafier=M/Exit=X
DF
Processing "Thor The Dark World (November 2013) 4K DV8_RPU - Copy.bin"
Exporting Scene cuts...
Parsing RPU file...
Exporting scenes list...
Done.
Check "G:\dovi\3.0.0\Thor The Dark World (November 2013) 4K DV8_RPU - Copy_scene-cuts.txt" and select if you have to add or remove a refresh flag(s)...
Do you want to add or remove scene_refresh_flag? choices are Add=a and Remove=r and press enter...
a
Which frames do you want to add a scene cut flag? (inclusive, default=0 1st frame)
Adding a Scene Cut flag at frame 0
Done.
1 file(s) copied.
Deleting TEMP folder...
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
edit:
some other bugs, clicking any button at the end after extracting RPU from the stream, starts the extraction process again
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Rororororo wrote:
Fri Aug 02, 2024 7:08 pm
Right you cant resync and edit the scene cut at the same time and I didn't write it in the exception because you can select 569f or 569d but not 569fd
I wanted the options to all show up in a single line, and i got used to it, you will too. Feel free to tell me if you have a better idea.
7 = P7 to P8 (redirect to 4-1) This choice will only show up if your input is a P7 video
v = remover (redirect to 2-2) This choice will only show up if your input is a video file, you cant remove DV from a RPU input
fixed in beta
Rororororo
RESET_9999 wrote:
Fri Aug 02, 2024 8:29 pm
I'd at least separate them with spaces rather than slashes, swap the value with the description and use one letter case.
Thanks for clarifications.
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Rororororo wrote:
Fri Aug 02, 2024 10:08 pm
this should be better:
Arq231
Post by Arq231 »
RESET_9999 wrote:
Fri Aug 02, 2024 6:27 pm
just look on the Resolve media page, and you will find the framecount of the prores file.
Then in the xml, modify the duration of the last shot(probably just 57 or 55) to match that framecount.
How to fix the RPU mismatch problem?
Do I only need to modify the duration for the last scene??
Also how can I re-encode the remux while retaining the Dolby Vision metadata? Which software allows this?
Arq231 wrote:
Sat Aug 03, 2024 5:32 am
yes
encoding scripts in my signature.
Rororororo
RESET_9999 wrote:
Sat Aug 03, 2024 12:23 am
That's better IHMO.
Would be possible to add an option for batch extraction or metafier procceses etc?
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Rororororo wrote:
Sun Aug 04, 2024 6:16 pm
I think you can already do that.
if you input a folder and select ''E'' in Mode.I (1), it should redirect to the batch L1 plotter workflow (6-3) which can batch extract.
metafier: no
deadchip12
Post by deadchip12 »
@RESET_9999
I'm trying the latest version of Dovi_Scripts to see if the workflow for injecting stream's DV cmv4.0 into bluray's DV cmv2.9/HDR10 is any different. Have a few questions:
1) Workflow 6-4: now running it with the stream video file produces additional 2 graphs which are L8.HUE.Vector.Field.PLOT and L8.Saturation.Vector.Field.PLOT. What are these used for?
2) Workflow 2-4 in the old version is used to find frame difference between the bluray and stream file, but now it's no longer there? What is the workflow now?
Would be great if you can update the tutorial videos. Thanks.
it's not
it's now workflow 9-1
deadchip12 wrote:
Mon Aug 05, 2024 3:26 am
They are the extra control for color saturation and hue in cmv4.0. Used mostly for fine-tuning the colors in 100nits trim pass.
Rororororo
RESET_9999 wrote:
Sun Aug 04, 2024 8:09 pm
metafier: no
Yeah, I tried that before posting and it didn't work in both 3.0.0 and 3.0.1, only extracted from the first mkv in the folder
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
It works in the latest beta, I just tried it.
deadchip12
RESET_9999 wrote:
Mon Aug 05, 2024 3:54 am
it's not
Thanks. What is the workflow for exporting scene cuts now? It was 2-3 before.
2-1 or 1-s
deadchip12
RESET_9999 wrote:
Tue Aug 06, 2024 12:54 am
2-1 or 1-s
Thanks again. Btw, I see John Wick Chapter 4 is put in the red table. Have you tested it for the green table? I see Super Mario Bros 2023 in both red and green table.
