poly888
Post by poly888 » Sun Jul 28, 2024 10:03 am
RESET_9999 wrote: Thu Jul 25, 2024 4:23 pm the best trackers dont let people in for money.
You need to get invited by someone already in but I believe they are sometimes recruiting users from other private trackers so you might be lucky if you are on one of those trackers...
https://www.reddit.com/r/trackers/
This is the first time I hear about such system, why wouldn't a pay version be good? I mean you give money for access no?
Post by RESET_9999 » Sun Jul 28, 2024 12:30 pm
i dont know
kazuma
Post by kazuma » Sun Jul 28, 2024 4:33 pm
Does nobody have a invite for BHD? What is the website?
deadchip12
Post by deadchip12 » Wed Jul 31, 2024 1:50 pm
I wonder why the subtitles of 4k hdr films are super bright when I watch it on the sony x700 (for which I have to manually extract the subtitles and lower their brightness using external software), but now on the ugoos am6b+ they are appropriately bright.
Rororororo
Post by Rororororo » Thu Aug 01, 2024 9:25 pm
@RESET_9999
just checking 3.0.0, what does it mean and why is it bad (red)
1st Frame is a Scene Cut: YES (good)
Consecutive Scene Cuts: YES
Base Layer: ICtCp (DoVi P5)
Edit:
ok got it "D/SC_Flag=F" is old 2-1-1 to fix it
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Post by RESET_9999 » Thu Aug 01, 2024 11:36 pm
it's just a warning. Dont edit it if it's from a retail source.
This is for the old P8 hybrid remux when we were not duplicating or removing frames correctly as explained here:
viewtopic.php?p=155652#p155652
Rororororo
Post by Rororororo » Fri Aug 02, 2024 3:18 am
This is actually from such P8 remuxes, I was checking some
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Arq231
Post by Arq231 » Fri Aug 02, 2024 12:28 pm
How to fix the RPU mismatch problem? the last frame in most of the cut-scenes has different brightness than the cut-scene itself.
I'm unable to import the movie into Resolve directly in its RAW format. However, I'm able to when I trim it using ffmpeg to keep its properties unchanged otherwise it would lose its HDR format.
I would like to convert this movie into SDR Dolby Vision.
Any suggestions?
Here are the movie properties:
Format                         : Matroska
Format version                 : Version 4
File size                      : 43.3 GiB
Duration                       : 1 h 31 min
Overall bit rate mode          : Variable
Overall bit rate               : 67.7 Mb/s
Frame rate                     : 23.976 FPS
Movie name                     : Rocky.IV.1985.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT
Encoded date                   : 2023-02-28 07:33:24 UTC
Writing application            : mkvmerge v74.0.0 ('You Oughta Know') 64-bit
Writing library                : libebml v1.4.4 + libmatroska v1.7.1
Video
ID in the original source medi : 4113 (0x1011)
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main 10@L5.1@High
HDR format                     : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                       : V_MPEGH/ISO/HEVC
Bit rate                       : 58.9 Mb/s
Width                          : 3 840 pixels
Height                         : 2 160 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0 (Type 2)
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.296
Stream size                    : 37.6 GiB (87%)
Language                       : English
Default                        : No
Forced                         : No
Color range                    : Limited
Color primaries                : BT.2020
Transfer characteristics       : PQ
Matrix coefficients            : BT.2020 non-constant
Mastering display color primar : Display P3
Mastering display luminance    : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level    : 3992 cd/m2
Maximum Frame-Average Light Le : 1649 cd/m2
Original source medium         : Blu-ray
XML file last entries:
            <Record>
              <In>120488</In>
              <Duration>56</Duration>
            </Record>
            <PluginNode>
              <DolbyEDR level="1">
                <ImageCharacter>0.0004884005,0.22857143,0.63565326</ImageCharacter>
              </DolbyEDR>
              <DolbyEDR level="2">
                <TID>1</TID>
                <Trim>0,0,0,0,0,-0.063356996,0,0.08154297,0</Trim>
              </DolbyEDR>
            </PluginNode>
          </Shot>
        </Track>
      </Video>
    </Output>
  </Outputs>
</DolbyLabsMDF>
Post by RESET_9999 » Fri Aug 02, 2024 6:27 pm
just look on the Resolve media page, and you will find the framecount of the prores file.
Then in the xml, modify the duration of the last shot(probably just 57 or 55) to match that framecount.
Rororororo
Post by Rororororo » Fri Aug 02, 2024 7:08 pm
some combination in the new MODE.I (1) in 3.0.0/3.0.1 seems not to work like "DF", the section with options is a bit confusing and could be a bit more readable, also what are valves v and 7?
*You can select more than one value(except: e/m/p/s/7/v) but no space between values: EG: 569r4 (default= Exit)
L5=5/L6=6/L9=9/Resync=R or D/SC_Flag=F/RemCMV4=4 - /PLOT=P/CheckSync=S/Read=E/Metafier=M/Exit=X
DF
Processing "Thor The Dark World (November 2013) 4K DV8_RPU - Copy.bin"
Exporting Scene cuts...
Parsing RPU file...
Exporting scenes list...
Done.
Check "G:\dovi\3.0.0\Thor The Dark World (November 2013) 4K DV8_RPU - Copy_scene-cuts.txt" and select if you have to add or remove a refresh flag(s)...
Do you want to add or remove scene_refresh_flag? choices are Add=a and Remove=r and press enter...
a
Which frames do you want to add a scene cut flag? (inclusive, default=0 1st frame)
Adding a Scene Cut flag at frame 0
Done.
1 file(s) copied.
Deleting TEMP folder...
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
edit:
some other bugs, clicking any button at the end after extracting RPU from the stream, starts the extraction process again
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Post by RESET_9999 » Fri Aug 02, 2024 8:29 pm
Rororororo wrote: Fri Aug 02, 2024 7:08 pm some combination in the new MODE.I (1) in 3.0.0/3.0.1 seems not to work like "DF"
Right you cant resync and edit the scene cut at the same time and I didn't write it in the exception because you can select 569f or 569d but not 569fd
I wanted the options to all show up in a single line, and i got used to it, you will too. Feel free to tell me if you have a better idea.
7 = P7 to P8 (redirect to 4-1) This choice will only show up if your input is a P7 video
v = remover (redirect to 2-2) This choice will only show up if your input is a video file, you cant remove DV from a RPU input
fixed in beta
Rororororo
Post by Rororororo » Fri Aug 02, 2024 10:08 pm
RESET_9999 wrote: Fri Aug 02, 2024 8:29 pm I wanted the options to all show up in a single line, and i got used to it, you will too. Feel free to tell me if you have a better idea.
I'd at least separate them with spaces rather than slashes, swap the value with the description and use one letter case.
Thanks for clarifications.
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Post by RESET_9999 » Sat Aug 03, 2024 12:23 am
Rororororo wrote: Fri Aug 02, 2024 10:08 pm I'd at least separate them with spaces rather than slashes, swap the value with the description and use one letter case.
this should be better:
Arq231
Post by Arq231 » Sat Aug 03, 2024 5:32 am
RESET_9999 wrote: Fri Aug 02, 2024 6:27 pm just look on the Resolve media page, and you will find the framecount of the prores file.
Do I only need to modify the duration for the last scene??
Also how can I re-encode the remux while retaining the Dolby Vision metadata? Which software allows this?
Post by RESET_9999 » Sat Aug 03, 2024 8:55 pm
Arq231 wrote: Sat Aug 03, 2024 5:32 am Do I only need to modify the duration for the last scene??
yes
encoding scripts in my signature.
