very simple but not sure if you want to do thatrye-amts wrote: Wed May 01, 2024 10:26 pmI suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?Billycar11 wrote: Wed May 01, 2024 9:55 pm on mac your out of luck
if you have access to a pc email me that drive info and i can sell you an automated flasher for $25
ASUS SBW-06D2X-U
Re: ASUS SBW-06D2X-U
I've recently purchased an ASUS SBW-06D2X-U external blu ray player/fingerprint magnet, can I ask the procedure to make it LibreDrive enabled?.
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.11
Serial number: [redacted]
Firmware date: 2023-04-20
Firmware version: ID22
Manufacturer: ASUS
Revision: 1.11
email me for the flash kit see belowMalloc wrote: Thu May 30, 2024 2:59 am I've recently purchased an ASUS SBW-06D2X-U external blu ray player/fingerprint magnet, can I ask the procedure to make it LibreDrive enabled?.
Manufacturer: ASUS
Revision: 1.11
mentolathum
Hello, I just bought that same unit, could someone please give me the instructions to do the flashing?
I also have this drive however this is what it shows on makemkv
Manufacturer: ASUS
Revision: D601
Highest AACS version: 65-
ricurreli96
Hi, i also have a ASUS SBW-06D2X-U drive and i really want also the procedure to make it LibreDrive enabled with UHDs, please send me the instructions!Coopervid wrote: Wed Apr 03, 2024 9:42 pm This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Manufacturer: ASUS
Revision: 1.10
Firmware date: 2017-04-18
Highest AACS version: 66
Read your PM.rye-amts wrote: Wed May 01, 2024 10:26 pmI suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?Billycar11 wrote: Wed May 01, 2024 9:55 pm on mac your out of luck
PM sentricurreli96 wrote: Wed Jul 31, 2024 1:02 pmHi, i also have a ASUS SBW-06D2X-U drive and i really want also the procedure to make it LibreDrive enabled with UHDs, please send me the instructions!Coopervid wrote: Wed Apr 03, 2024 9:42 pm This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Manufacturer: ASUS
Revision: 1.10
ricurreli96
Thank you very much, it worked!Coopervid wrote: Wed Jul 31, 2024 10:51 pmPM sentricurreli96 wrote: Wed Jul 31, 2024 1:02 pmHi, i also have a ASUS SBW-06D2X-U drive and i really want also the procedure to make it LibreDrive enabled with UHDs, please send me the instructions!Coopervid wrote: Wed Apr 03, 2024 9:42 pm This drive can be upgraded to UD04 and can read UHDs and will be Libredrive compatible.Read your PM.
Manufacturer: ASUS
Revision: 1.10
ricurreli96
Hi again, i have a question:ricurreli96 wrote: Thu Aug 01, 2024 12:10 amThank you very much, it worked!Coopervid wrote: Wed Jul 31, 2024 10:51 pmPM sentricurreli96 wrote: Wed Jul 31, 2024 1:02 pm
Manufacturer: ASUS
Revision: 1.10
how is it possible that the drive is now capable of read 4k Ultra HD disk?
should be physically impossible!
The hardware was always capable. Your original firmware was just "crippled".ricurreli96 wrote: Thu Aug 01, 2024 11:06 pmHi again, i have a question:
Your PM will expire tomorrow.rye-amts wrote: Wed May 01, 2024 10:26 pmI suspected this could be the case. How unfortunate. I could probably get access to my wife's PC at her work. Is it a simple procedure?Billycar11 wrote: Wed May 01, 2024 9:55 pm on mac your out of luck
Would I be able to get the instructions as well? Here's my drive information:
OS device name: E:
Manufacturer: ASUS
Revision: D501
Highest AACS version: 68
OS device name: E:
Manufacturer: ASUS
Revision: D501
The drive platform information is missing.centrafl wrote: Thu Aug 08, 2024 8:05 am Would I be able to get the instructions as well? Here's my drive information:
OS device name: E:
Manufacturer: ASUS
Revision: D501
Libre drive information doesn't pull up for that drive for some reason, but for other drives it does. Does that mean its not supported?
