I got a brend new PC and a new external optical device: BD-RW BDR-X13U
I tried to use it to make a backup of a bluray movie with makemkv but it looks like it's not supported...
Can you help me to buy a new one which will work with makemkv and will support 4K/UHD br movie
Thanks in advance for your reply.
Regards.
Beyond63
BD-RW BDR-X13U
Re: BD-RW BDR-X13U
Post the makemkv drive info section.
It the fw is after 12/22 it won't do UHD anytime soon.
But I have those with old fw if you want one see below
You will just need a usb case like the owc mercury pro
Beyond63
Re: BD-RW BDR-X13U
Informations lecteur
Nom du lecteur SE : G:
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-X13U
Révision : 1.03
Numéro de série : *********
Date micrologiciel : 2022-12-12
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 77
Firmware version: ID29
what do you think? any chance to make it work?
Fabricant : PIONEER
Révision : 1.03
Re: BD-RW BDR-X13U
No.Beyond63 wrote: Fri Aug 02, 2024 6:30 pm Informations lecteur
Fabricant : PIONEER
Révision : 1.03
Fortinbras
Re: BD-RW BDR-X13U
Hi guys - firstly, thanks for all your work.
Based on what I've read, pretty sure I'm sh*t out of luck with this drive for UHD, but just confirming:
Manufacturer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.04
Serial number: ******************
Firmware date: 2023-08-01
Highest AACS version: 72
Re: BD-RW BDR-X13U
You are correct. That drive's firmware is too new.Fortinbras wrote: Tue Aug 27, 2024 6:16 pm Hi guys - firstly, thanks for all your work.
Revision: 1.04
