Hi all,
I'm trying to run the SDFtool Flasher but I'm getting an error.
I'm running Windows 11 and using a Buffalo BRUHD-PU3-BK.
The app does launch but shows no drives present.
Here is a link to a screenshot of the error >>> https://imgur.com/mPOyBaU
Error code below:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.5.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************
Riku55
Re: SDFtool Flasher
Just downloaded the flasher today and got the exact same error as @MilesPNZ but on Windows 10.
Re: SDFtool Flasher
Is MakeMKV installed? SDFtool Flasher is a front-end for MakeMKV's native command line tool.Riku55 wrote: Tue Aug 13, 2024 6:19 pm Just downloaded the flasher today and got the exact same error as @MilesPNZ but on Windows 10.
Requirements:
- Windows 10 64 bit version
- MakeMKV v1.15.1 (or higher) installed
- .NET Framework 4.7.2 **only for SDFtool Flasher v1.2.0**
Riku55
Re: SDFtool Flasher
Oooh, I see. Didn't when trying the first time. Installed MakeMKV later but didn't retest it. It's working now. Sorry for being just another user who didn't read the requirements :'D
MilesPNZ
Re: SDFtool Flasher
Thank you!d00zah wrote: Tue Aug 13, 2024 6:44 pmIs MakeMKV installed? SDFtool Flasher is a front-end for MakeMKV's native command line tool.Riku55 wrote: Tue Aug 13, 2024 6:19 pm Just downloaded the flasher today and got the exact same error as @MilesPNZ but on Windows 10.
Requirements:
My COVID brain missed this bit!
MilesPNZ
Re: SDFtool Flasher
Hoping somebody can help me with another question.
I'm using my Buffalo BRUHD-PU3-BK but I'm not sure exactly what firmware to flash to it.
I flashed DE_Buffalo_BRUHD-PU3_BU12-MK.bin which was sucessful but it still doesn't seem able to get the MKV from my BluRay (I'm using my copy of The Martian).
It's just spitting out errors.
Re: SDFtool Flasher
It would help enormously if you could share (copy/paste) the log so we can review the errors.MilesPNZ wrote: Wed Aug 14, 2024 5:44 am Hoping somebody can help me with another question.
Luthex
Re: SDFtool Flasher
Could i get the .bin file for Pioneer XD08U1? Thank you
Re: SDFtool Flasher
There isn't one! Also, that drive isn't flashable nor downgradable.
citykid3165
Re: SDFtool Flasher
Hi there.segfaulted wrote: Thu Aug 01, 2024 2:43 am Use RECOVER mode. You'll point it to the current firmware file, which might be DE_LG_WP50NB40-NB50_1.03_MK.bin if UHD discs haven't worked in your drive. Then you can select the firmware that you want to flash, choose DE_LG_BU40N_1.00.bin
The drive's LED light should blink during the flashing process if you did it correctly. If it doesn't blink, the drive is ignoring the reflash.
I tried following these instructions and it didn't work for my LG BP50NB40 and it still doesn't read discs even though it says it's patched.
The drive tries to load the discs but fail and the firmware stays on version 1.03.
I did the following
- RECOVERY and flashed HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917
- WRITE and flashed DE_LG BU40N_1.00
Surely I'm missing something here? I'm getting really confused. If someone could point me towards a guide that would be really good if possible.
This is what the info on MakeMKV says with a UHD disc in:
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK05O4O85803
Highest AACS version: 65
Firmware version: 1.03
citykid3165
Re: SDFtool Flasher
Hi - I followed these exact instructions yet it still doesn't want to read my UHD discs.MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware in the normal drop box.
4. Click START
Firmware went through properly on the software however the drive doesn't show an indicator light whilst doing so.
I've used the firmwares in your firmware pack and still no dice and it still shows at BP50NB40.
I'm unsure on what to do. Only difference is that one of the ports may be USB 2.0 but shouldn't matter at least I think...
This is what MakeMKV says in the info:
OS device name: F:
Revision: 1.03
Re: SDFtool Flasher
You are still on BP50 firmware therefore you did not follow the instructions correctly.citykid3165 wrote: Thu Aug 22, 2024 11:33 amHi - I followed these exact instructions yet it still doesn't want to read my UHD discs.MartyMcNuts wrote: Tue Aug 18, 2020 1:39 am For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
4. Click START
This is what MakeMKV says in the info:Code: Select all
Drive Information OS device name: F: Manufacturer: HL-DT-ST Product: BD-RE BP50NB40 Revision: 1.03 Serial number: SIK05O4O85803 Firmware date: 2120-05-07 09:17 Bus encryption flags: 17 Highest AACS version: 65 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Patched (microcode access re-enabled) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Do it again from step 2. Read the title bar of each popup window.
segfaulted
Re: SDFtool Flasher
That doesn't sound right. You've already done one WRITE to get on 1.03-MK, so skip that function from now on. Do the cross-flash with RECOVER.citykid3165 wrote: Thu Aug 22, 2024 10:54 am I did the following
When you choose RECOVER, the tool will first ask for the current firmware file... choose BP50NB40 1.03-MK. Then you click the dropdown and choose the firmware you actually want to flash, BU40N 1.00 and start the flash. Don't click on WRITE.
Re: SDFtool Flasher
Which is precisely what the instructions from step 2 are telling him to do. He's just not following them correctly.segfaulted wrote: Thu Aug 22, 2024 11:57 pmThat doesn't sound right. You've already done one WRITE to get on 1.03-MK, so skip that function from now on. Do the cross-flash with RECOVER.citykid3165 wrote: Thu Aug 22, 2024 10:54 am I did the following
citykid3165
Re: SDFtool Flasher
Whoops my mistake... so there were two different prompts. I thought the first one didn't worksegfaulted wrote: Thu Aug 22, 2024 11:57 pm
I'll try again once I get home, thank you!
