SCARFACE,...help please?
servocrow101
Post by servocrow101 »
Unable to rip this BLURAY using almost ANY tool, INCLUDING MAKEMKV, any suggestions???
setarip_old
Re: SCARFACE, blasted Cinavia...help please?
Post by setarip_old »
Hi!
"Cinavia"/Verance protection IN NO WAY prevents you from making a backup. What it does is disrupt and/or stop proper PLAYBACK on many standard (not "jailbroken") PS3s and (thusfar) on a handful of standalone Blu-ray players.
If you're saying that you cannot make a backup at all, that's definitely nothing to do with "Cinavia"/Verance.
On the other hand, if you're saying you've successfuly made a playback, but it's useless because when played, it generates a "Cinavia" notification and interferes with or stops further playback, presently, the only real options are to purchase one of the many players that do not recognize this protection or, if you're using an "infected" PS3, seek out products that can either rollback its firmwareto its pre-"Cinavia" condition or circumvent the "Cinavia" coding ("jailbreaking" or various dongles).
Another alternative, from the authors at DVDFab requires the use of 50GB media and the creation of a different Blu-ray format...
servocrow101
Re: SCARFACE, ...help please?
Ohhh gotcha!
Its def. not a Cinavia issue then HOWEVER i still am unable to rip this BR.
Any suggestions?
I have tried DVDFAB, passkey, anydvd, and MAKEMKV...no dice !
setarip_old
1) Specifically WHAT happens when you try to make a backup copy (either full disc or .MKV)? Describe what hapens separately with each program you've tried to use.
2) Try again with MakeMKV and submit the log.
3) Is this a new Blu-ray release of "Scarface", or the one from (IIRC) 2005?
servocrow101
they just stall out in middle of the rip and it mooooovvvvveeess sooo slow !
will submit log in a few...") Thx :)
YES its the NEW BLURAY release!!
servocrow101
Re: SCARFACE,...help please?
MakeMKV v1.6.14 win(x64-release) started
Title #00013.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00020.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50057.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50058.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50277.m2ts has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50278.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50283.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50284.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00301.m2ts was added as title #1
File 00302.m2ts was added as title #2
File 00303.m2ts was added as title #3
File 00304.m2ts was added as title #4
File 00305.m2ts was added as title #5
File 00306.m2ts was added as title #6
File 00307.m2ts was added as title #7
File 00308.m2ts was added as title #8
File 00309.m2ts was added as title #9
File 00310.m2ts was added as title #10
Title #50199.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50200.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.m2ts was added as title #11
Title #00311.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/XXXX/Desktop
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '24638914560'
Failed to save title 0 to file C:/Users/XXXX/Desktop/title00.mkv
0 titles saved, 1 failed
someone please tell me whats up?
crowfax
Post by crowfax »
Damaged disc. Return it for a new one.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
