Creating a dumpfile on Windows
Spectre-21
Post by Spectre-21 » Wed Jul 31, 2024 2:27 pm
I just gut the Spongebob Squarepants 4k UHD and tried to extract the mkv through makemkv. Unfortunately it did not work, with the error "volume key is unknown for this disc". So far I get the key is missing and that I can send in the dump so that the key gets created so that I can decrypt the disk.
My issue is i cant find the dump on Windows 11 even after extensive research. Am I missing/overlooked something?
Re: Creating a dumpfile on Windows
Post by Woodstock » Wed Jul 31, 2024 4:12 pm
Where did the program SAY it was creating the dump file at? It should have been listed as part of the dialog about not being able to rip the disk.
The file will be the name of the disk, with a 4-character code at the end, and ".tgz" as the file extension.
Possible exception is if your configuration is trying to write it to a no-write area, but even that should be noted on the display.
Monkeylord
Post by Monkeylord » Wed Jul 31, 2024 11:37 pm
Also useful to know, the actual message saying the name of the dumpfile created is in fact a link. Click on it and it will open a window to your MakeMKV directory where all generated dump files are stored.
Spectre-21
Post by Spectre-21 » Wed Aug 07, 2024 12:23 pm
Hi guys thanks for the input. I managed to around this issue by enabling the vlc integration. Today I tried to rip the new civial war 4k disk and got the same error but this time with a clickable link.
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as C:\Users\XXX/.MakeMKV/MKB20_v77_Civil_War_-_UHD_33A2.tgz
I am fairly certain that the link was not present with the two other disc I've mentioned. But either way it's resolved nor and I've submitted the dump for civial war, thanks for your help. :)
