New user, decided to convert my DVD Collection to MKV and free up some space.
I've managed to burn over 100 so far but ran into the first problem I could not solve by messing with settings...
Drive DVD+R-DL ASUS DVD RAM GH95N AS00 K6UD1T32828 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
IFO file for VTS #4 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 in broken titleset was skipped
Title #2 in broken titleset was skipped
Calculated TVOB offset for VTS #4 does not match one in IFO header.
Title #4 in broken titleset was skipped
Title #5 in broken titleset was skipped
Title #6 in broken titleset was skipped
DVD is clean.. not a speck on it. I really don't want to change regions again.. Any suggestions?
PS - As an Added Bonus Grease 2 won't Open either... same messages... Same Manufacturer of the disc.. Paramount... If that helps/matters.
Grease DVD
Re: Grease DVD
Do you have a LibreDrive capable drive you can use? It won't care what region your DVD is.
