I have an LG BP60NB10, some UHD discs and some Bluray discs read properly, but others fail with M2TS errors and CDB errors. For example, Starship Troopers UHD and Austin Powers International Man of Mystery Bluray all work fine. Starship Troopers Bluray and Apollo 13 UHD do not work.
Is this a sufficient sign of a failed drive that I should return, or is that more an indication of failed discs?
Do Inconsistent Errors Always Mean A Failed Drive?
snthsnth
Re: Do Inconsistent Errors Always Mean A Failed Drive?
HOW do the discs fail? Do they start the rip & die somewhere in progress? Or, w/ UHD (see FAQ), is the log reporting volume key not found? A log helps people trying to assist.snthsnth wrote: Wed Jul 31, 2024 6:34 am I have an LG BP60NB10, some UHD discs and some Bluray discs read properly, but others fail with M2TS errors and CDB errors. For example, Starship Troopers UHD and Austin Powers International Man of Mystery Bluray all work fine. Starship Troopers Bluray and Apollo 13 UHD do not work.
Sometimes, all that's required is cleaning the disc w/ a lint-free cloth. Sometimes with a little mild soap/water. No matter how pristine a disc may appear to the human eye,a laser is more discerning.
Sometimes the disc is bad. Could be a bad pressing? The higher the data density of the disc (UHD 3-layer are the most difficult), the more likely a drive may take issue.
With LG and Asus drives you need to reboot them anytime they do stuff like that.
It very common it's not failed but some drive require a reboot after every disc.
Really they are just annoying sadly.
Pioneers are not like this they are way better but you need them with old fw and only a few have them me Marty and Asmcom are the only ones I know of with latest Gen pioneers with old fw
snthsnth
Since I didn't save a copy of the logs, so I retried the non-working discs. The Starship Troopers Bluray worked without issue this time.
EDIT: I should add, I tried unplugging and replugging the drive, gently cleaning the discs, and removing, rotating, and reinserting discs, without any apparent change.
I pruned out a bunch of duplicate 'corrupt or invalid' messages, I was around 120k characters with them in.
Apollo 13 UHD:
National Treasure Bluray:
Austin Powers Goldmember Bluray
Apollo 13 UHD:
Saving 1 titles into directory X:/Video/Apollo 13
Hash check failed for file 00093.m2ts at offset 22196643840, file is corrupt.
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211917824, attempting to work around
Hash check failed for file 00093.m2ts at offset 22211979264, file is corrupt.
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211936256, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211936256-22211942400, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211942400, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211942400-22211948544, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211948544, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211973120, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211973120-22211979264, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22211979264, attempting to work around
The source file '/BDMV/STREAM/00093.m2ts' is corrupt or invalid at offset 22216175616, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00093.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00093.m2ts at offset 22216304640, file is corrupt.
Hash check failed for file 00093.m2ts at offset 22216697856, file is corrupt.
Hash check failed for file 00093.m2ts at offset 22217091072, file is corrupt.
Too many hash check errors in file 00093.m2ts.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00093.m2ts' at offset '22217355264'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '22217355264'
Failed to save title 3 to file X:/Video/Apollo 13/Apollo 13_t03.mkv
Encountered 5 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
0 titles saved, 1 failedCode: Select all
Saving 1 titles into directory X:/Video/NATIONAL_TREASURE
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467864576, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467864576-10467870720, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467870720, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467870720-10467876864, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467876864, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467876864-10467883008, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467883008, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467883008-10467889152, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 10467889152, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00136.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00136.m2ts at offset 10467993600, file is corrupt.
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 15774437376, attempting to work around
Hash check failed for file 00136.m2ts at offset 15774443520, file is corrupt.
Hash check failed for file 00136.m2ts at offset 15923472384, file is corrupt.
Hash check failed for file 00136.m2ts at offset 16003688448, file is corrupt.
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16037056512, attempting to work around
Hash check failed for file 00136.m2ts at offset 16037111808, file is corrupt.
Too many hash check errors in file 00136.m2ts.
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16041025536, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16169865216, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16275628032, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16387375104, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16387375104-16387381248, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16387381248, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16446050304, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16446087168, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16450387968, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16466049024, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16466073600, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16500492288-16500498432, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16500498432, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16500541440, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16500559872, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16501702656, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16501727232, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16501727232-16501733376, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16501733376, attempting to work around
The source file '/BDMV/STREAM/00136.m2ts' is corrupt or invalid at offset 16501733376-16501739520, attempting to work around
Failed to save title 0 to file X:/Video/NATIONAL_TREASURE/title_t00.mkv
Encountered 353 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Saving 1 titles into directory X:/Video/Austin Powers In Goldmember
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018368512, attempting to work around
Hash check failed for file 00001.m2ts at offset 20018423808, file is corrupt.
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018386944, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018399232, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018411520, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018411520-20018417664, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018497536, attempting to work around
Hash check failed for file 00001.m2ts at offset 20018620416, file is corrupt.
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018497536-20018503680, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018503680, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018503680-20018509824, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20018509824, attempting to work around
Too many AV synchronization issues in file '/BDMV/STREAM/00001.m2ts' (title #-) , future messages will be printed only to log file
Hash check failed for file 00001.m2ts at offset 20019013632, file is corrupt.
Hash check failed for file 00001.m2ts at offset 20019800064, file is corrupt.
Hash check failed for file 00001.m2ts at offset 20021372928, file is corrupt.
Too many hash check errors in file 00001.m2ts.
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20032192512, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20032217088, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20032217088-20032223232, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20032223232, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20040142848-20040148992, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20040148992, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20133986304, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20134010880, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20205735936, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20205748224, attempting to work around
The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 20205778944, attempting to work around
Encountered 39 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
1 titles saved-
snthsnth
I have now tried about 40 disks, most of them work properly. I think I lucked into half a dozen bad disks in the first ten I tried, giving me the impression of a bad drive. I am fairly certain that I simply have some bad disks.
