Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Post by Coopervid » Tue Jul 30, 2024 5:47 pm
redmarple wrote: Tue Jul 30, 2024 3:21 pm Hey Coopervid,
also got this drive for free. Would love to be able to read UHD. Thanks in advance.
Am Linux user but got my Windows Desktop prepared for flashing.
OS device name: J:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number: [redacted]
Firmware date: 2015-05-14
Highest AACS version: 81
Drive platform: RS8510
Firmware version: 1.03/ID19
Check your PM and use Windows.
redmarple
Post by redmarple » Tue Jul 30, 2024 6:24 pm
Thanks a lot. Works. The old 1.03 Firmware seemed to have a lot of bugs. They are also gone now.
itsoreo
Post by itsoreo » Wed Jul 31, 2024 6:05 am
Hello Coopervid,
I got a UD03 not realizing it didn't support 4k natively. Would really appreciate being able to add that.
Post by Coopervid » Thu Aug 01, 2024 9:26 am
itsoreo wrote: Wed Jul 31, 2024 6:05 am Hello Coopervid,
PM sent.
lega24
Post by lega24 » Fri Aug 02, 2024 6:10 pm
hi I have a "Pioneer BDR-UD03B" with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to make it recognize UHD discs and rip them?
Thanks..
Informations lecteur
Nom du lecteur SE : G:
Fabricant : PIONEER
Produit : BD-RW BDR-UD03
Révision : 1.11
Numéro de série : [redacted]
Date micrologiciel : 2018-11-28
Marqueurs d'encryptage bus : 1B
Drive platform: RS8511
Firmware version: 1.11
Aucun disque
Post by Coopervid » Sat Aug 03, 2024 9:10 am
lega24 wrote: Fri Aug 02, 2024 6:10 pm hi I have a "Pioneer BDR-UD03B" with BDXL icon on it. I try to read a UHD disc and it doesn't work. Is it possible to make it recognize UHD discs and rip them?
Thanks..
Fabricant : PIONEER
Révision : 1.11
Aucun disque
PM sent.
djfix13
Post by djfix13 » Sat Aug 03, 2024 5:32 pm
sorry, I'm new and I have now purchased a Verbatim with this Pioneer BDR-UD03 with firmware 1.14 inside
I know you will PM me to read 4K discs
I'm waiting
Thank you
Post by Coopervid » Sat Aug 03, 2024 7:09 pm
djfix13 wrote: Sat Aug 03, 2024 5:32 pm sorry, I'm new and I have now purchased a Verbatim with this Pioneer BDR-UD03 with firmware 1.14 inside
I'm waiting
Thank you
PM sent.
vidgonio
Post by vidgonio » Mon Aug 05, 2024 3:31 am
Hi, can you help me?
My drive info is the following:
OS device name: H:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Firmware date: 2018-08-22
Firmware version: E101/ID26
Thanks for any help you might provide in advance =)
Post by Coopervid » Mon Aug 05, 2024 5:22 pm
vidgonio wrote: Mon Aug 05, 2024 3:31 am Hi, can you help me?
OS device name: H:
Manufacturer: ASUS
Revision: E101
PM sent.
82318046
Post by 82318046 » Tue Aug 06, 2024 9:15 pm
Hi Coopervid,
I would really appreciate it if you could send me the the solution too :)
OS device name: /dev/sr0
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: XXXXXXXXXXXX
Firmware date: 2020-06-15
Bus encryption flags: XX
Highest AACS version: 76
Drive platform: RS8A10
Firmware version: 1.14
(This is from Linux, but I have a Windows system available if needed)
Thanks in advance
Post by Coopervid » Tue Aug 06, 2024 10:11 pm
82318046 wrote: Tue Aug 06, 2024 9:15 pm Hi Coopervid,
Revision: 1.14
Thanks in advance
This drive is already UHD capable.
82318046
Post by 82318046 » Tue Aug 06, 2024 11:18 pm
Coopervid wrote: Tue Aug 06, 2024 10:11 pm
Revision: 1.14
Thanks in advance
Thanks for the info. I tested it with one UHD disk already and it didn't work, but I will try again with a different disk and on Windows and will report back :)
Post by Coopervid » Tue Aug 06, 2024 11:25 pm
Let it read in by the OS and only then start the program.
82318046
Post by 82318046 » Tue Aug 06, 2024 11:49 pm
Coopervid wrote: Tue Aug 06, 2024 11:25 pm Let it read in by the OS and only then start the program.
It works ! Didn't even have to change to Windows and with the same disk, just a bit of patience before opening MakeMKV, thanks for that tip :)
I had no idea they still sold drives with old enough firmware, what a nice surprise.
Thank you for the time you spend helping people here !
