The West Wing - The Complete Series fails...
LGTrader
#1 Post by LGTrader » Tue Jul 16, 2024 3:14 pm
I'm a licensed user who has used the program for years. I bought what looks like a very clean set of DVDs on Ebay but most all of it is failing in MakeMKV. All discs have been cleaned and there are no obvious scratches. I have tried in both Kubuntu Linux and Windows with the same results. Note that the discs seem to play fine using VLC on Kubuntu.
SEASON 1: Disc 1 failed to rip any episodes. Disc 2 ripped 3 of 4. Disc 3 failed to rip any episodes
SEASON 2: Disc 1 failed to rip any episodes.
Same results on Windows and Linux. Tried 2 different USB DVD with no improvement. Using Ver 1.17.7 on Windows and I think 1.17.5 on Linux.
Hopefully someone can point me in a direction that will solve this. I don't know anything about expert mode so if I need to go there let me know what to do.
NOTE: In Windows the path to the log file appears to be incorrect as show in the 2nd line below.
MakeMKV v1.17.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Titan-R7/MakeMKV_log.txt
DEBUG: Code 100864256 at 8)gN3IM7_1@BG-`Ird:213132445
DEBUG: Code 100864256 at 8)gN3IM7_1@BG-`Ird:121262302
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading 'DVD+R-DL Dell DVD+/-RW DW316 A1C3 M0AO1FG5125' at offset '0'
DEBUG: Code 2 at {7bV/B`doBP)p9:29400232
DEBUG: Code 2 at {7bV/B`doBP)p9:29393631
DEBUG: Code 0 at 7>.d.te%a~E1LXAB5:121263245
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
DEBUG: Code 3 at {7bV/B`doBP)p9:29400232
DEBUG: Code 3 at {7bV/B`doBP)p9:29393631
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
DEBUG: Code 4 at {7bV/B`doBP)p9:29400232
DEBUG: Code 4 at {7bV/B`doBP)p9:29393631
DEBUG: Code 0 at tTE-~G2,q]Tk?NI1T<H-S0*:121263406
DEBUG: Code 4294967295 at C#v3ZeLtng**"0ionBl\:213133250
DEBUG: Code 0 at C#v3ZeLtng**"0ionBl\:121265062
DEBUG: Code 0 at C#v3ZeLtng**"0ionBl\:29394689
DEBUG: Code 0 at I5U/$`HTCgTZVw:29397104
DEBUG: Code 1840110 at {7bV/B`doBP)p9:213132721
DEBUG: Code 1953617 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2170445 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2347288 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2503282 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2722694 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2736457 at {7bV/B`doBP)p9:213132721
DEBUG: Code 2883113 at {7bV/B`doBP)p9:213132721
DEBUG: Code 3017837 at {7bV/B`doBP)p9:213132721
DEBUG: Code 3233314 at {7bV/B`doBP)p9:213132721
DEBUG: Code 3413497 at {7bV/B`doBP)p9:213132721
DEBUG: Code 3615401 at {7bV/B`doBP)p9:213132721
Title #1 declared length is 2:53:34 while its real length is 1:27:21 - assuming fake title
Re: The West Wing - The Complete Series fails...
#2 Post by d00zah » Tue Jul 16, 2024 3:49 pm
Experiment w/ the different DVD opening modes - CellWalk, CellTrim, CellFull
'CellTrim' has occasionally met w/ some success.
LGTrader
#3 Post by LGTrader » Tue Jul 23, 2024 6:29 pm
I tried with different opening methods on both Linux and Windows using makemkv.
I purchased a Windows DVD ripper and it failed also.
I decided the discs were just bad, or at least not worth the time, and send them back.
#4 Post by dcoke22 » Tue Jul 30, 2024 5:46 pm
harrystyles wrote:
Tue Jul 30, 2024 3:06 am
I tried the above solution but it still fails. Do you have any other idea on this?
What does the MakeMKV log show? Can you copy & paste it into a post here?
