The Girl Who Played With Fire
Ryanide
Post by Ryanide »
This Blu-ray has both English and Swedish Audio and English subtitles.
I can't Open the disc because I get the error: The volume key is unknown for this disc - video can't be decrypted.
However, I did a backup and it was able to decrypt the backup. Then I opened the MKV file with MakeMVK and I selected the Title and the Swedish Audio (unchecked the English Audio) and checked the English (forced only) Subtitles. Then processed the file again like this to remove the English audio.
When I open the resulting file in the finder, it plays with Swedish Audio, but no subtitles. However, when I open that file in VCL player it shows the English subtitles as it should.
The problem is that Handbrake does not see the subtitles and therefore they are missing in the AppleTV converted file. Is there another way to force the subtitles to display that I'm missing? Or have I just gone about this all wrong?
I don't like the English Audio since the lips don't match.
Seems to be the same with the other 2 movies too (The Girl with the Dragon Tattoo. The Girl who Kicked the Hornet's Nest).
Romansh
Re: The Girl Who Played With Fire
Post by Romansh »
HandBrake does not support Blu-ray subtitles.
foodog
Post by foodog »
Ryanide wrote:This Blu-ray has both English and Swedish Audio and English subtitles.
If you are on a Mac use iVi not sure what to use if on a PC
Ryanide
Post by Ryanide »
Never heard of iVi. Looks good. I'll give it a try.
Ryanide
Post by Ryanide »
iVi worked to burn in the subtitles with the swedish audio into a MV4 file playable on Apple TV. The only problem is that the conversion took 20+ hours!!! : o
Thanks!!
