BW-16D1HT - Command produced error code 0xff278005
thepwrtank18
Post by thepwrtank18 » Tue Jul 30, 2024 3:30 am
I'm not able to flash my BW-16D1HT to the 3.10MK firmware from 3.11. I'm getting the following error:
>makemkvcon64.exe f --all-yes -d F: rawflash enc C:\Users\redacted\Downloads\ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Input file in raw format is required
DEBUG: Code 4280778757 at wfCw3OE9o6xoDD[;$ZOJdpeNgiQob2>_:29397978
OS device name: F:
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: [redacted]
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
Highest AACS version: 47
Re: BW-16D1HT - Command produced error code 0xff278005
Post by Billycar11 » Tue Jul 30, 2024 4:28 am
make sure its extracted and not in a zip folder.
or download the fw again and try 3.10mk or WH16NS60 1.02
thepwrtank18
Post by thepwrtank18 » Tue Jul 30, 2024 4:32 am
The bin file is extracted and outside of the mk-firmware-pack-20200720.zip folder. Here's the SHA1 of the firmware file if needed: 303a00628bbf67ee8ba61757d61c370e45bd4451
Post by Billycar11 » Tue Jul 30, 2024 4:34 am
thepwrtank18 wrote: Tue Jul 30, 2024 4:32 am The bin file is extracted and outside of the mk-firmware-pack-20200720.zip folder. Here's the SHA1 of the firmware file if needed: 303a00628bbf67ee8ba61757d61c370e45bd4451
try the all you need FW pack from guide below
thepwrtank18
Post by thepwrtank18 » Tue Jul 30, 2024 4:40 am
I was able to successfully flash 3.10MK to the drive with the SDFtool Flasher.
Just wondering, what's the difference between 3.10MK and WH16NS60 1.02, despite WH16NS60 being a cross-flash?
