The issue lies in piping data to other processes (the "ffmpeg ... - | dovi_tool ... -" part), so if you were simply using FFmpeg on its own, it would work the same.SciFinn wrote: Thu Mar 16, 2023 9:07 am Thank you! This was it. Didn't realize that Powershell could cause problems. I've never had any problem when using ffmpeg in powershell.
Dolby Vision x265 Encoding, DV Profile Advantages/Caveats?
quietvoid
Re: Dolby Vision x265 Encoding, DV Profile Advantages/Caveats?
JERisBRISK
Apologies for the "thread necro" but it appears this issue (and a followup one trying to pipe native binary output to a file) was fixed in Powershell 7.4.0-preview, so if you're running 7.4.0 release (or newer, current latest is 7.4.4) it should work fine.
I'm also curious if this process has been refined at all, or if better tools / automation exists?
I've got a rash of ISO backups of my physical media and I'm strongly considering remuxing them to MKV, but I don't want to lose DolbyVision (or other HDR10, etc.) in the process.
Has the "State of the art" improved in the last year and change?
The Ugoos AM6B+ running the latest versions of CoreELEC can play DV from a .mkv container in the format MakeMKV rips them from discs.JERisBRISK wrote: Mon Jul 29, 2024 12:48 am Apologies for the "thread necro" but it appears this issue (and a followup one trying to pipe native binary output to a file) was fixed in Powershell 7.4.0-preview, so if you're running 7.4.0 release (or newer, current latest is 7.4.4) it should work fine.
fe123
is it a problem if i not just crop but also scale (3840x2160 -> 1920x***) the original MKV while encoding and inject the RPU_81.bin afterwards?
fe123
I checked the parameters of the dovi_tool. There is a crop-parameter but not a scale parameter. I'm wondering if the final video will be OK if I downscale it during encoding. Unfortunately, I don't have the hardware to test this at the moment.fe123 wrote: Tue Mar 11, 2025 8:02 am Hello,
