RPC protection that can not be bypassed - error on v1.6.14
harrysdog
Post by harrysdog » Fri Sep 09, 2011 8:55 pm
greetings..
Been using earlier releases on trial basis..no problems at all converting blue rays. 50+ burned.
Got round to paying and now on MakeMKV v1.6.14 win(x64-release)
... First two films I have tried with this version (The Wrestler, Harry Potter 5).. report the folowing :
Drive BD-ROM PLEXTOR BD-ROM PX-B120U 1.06 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Did dig aronud, but cant find the firmeware for my model.
But it does seems a bit wierd that this worked perfectly fine with same BR drive in earlier version of makemkv..
Then I update to new version and get errors on first 2 films i have tried. Telling me its a drive issue...
setarip_old
Re: RPC protection that can not be bypassed - error on v1.6.
Post by setarip_old » Sat Sep 10, 2011 3:44 am
Hi!
If you re-try one or two of your earlier original, commercial Blu-ray discs that previously worked successfully with MakeMKV, does the current version of MakeMKV handle them properly?
Post by mike admin » Mon Sep 12, 2011 12:40 pm
This means that this particular drive is a bad choice for reading DVDs with mismatched region. Try copying these discs (as they should be rare) on another drive.
albourcin
Re: RPC protection that can not be bypassed - error on v1.6.14
Post by albourcin » Tue Feb 06, 2024 3:50 pm
Hi!
I have the same problem with a Salcar external DVD player. The codes on the System are:
DVDRAM GUA0N :
ID prodotto: 0x3940
ID fornitore: 0x13fd (Initio Corporation)
Versione: 3.10
Numero di serie: 4D333544423939313931352020202020
Velocità: Fino a 480 Mb/s
Produttore: HL-DT-ST
ID posizione: 0x14100000 / 3
Corrente disponibile (mA): 500
Corrente necessaria (mA): 100
Corrente operativa extra (mA): 0
Do I have to change dvd player?
Wich model just not to waste money again?
Thank you!
Post by dcoke22 » Wed Feb 07, 2024 4:38 am
The Ultimate UHD Drives Flashing Guide includes a list of recommended drives if you're going to buy a new drive.
albourcin
Post by albourcin » Wed Feb 07, 2024 8:45 am
Any way to solve the problem without buying a new drive?
Post by Billycar11 » Thu Feb 08, 2024 9:55 am
albourcin wrote: Wed Feb 07, 2024 8:45 am Thanks!
If your discs are mostly the same region you can try changing the region to match the discs
GJamesB
Post by GJamesB » Sun Aug 10, 2025 1:17 am
I'm suddenly getting this error with 1.18.1 on macOS Sequoia 15.5. A DVD correctly ripped, then the second disc from the same title got this error. Other discs, including the previously successful disc, now produce the error. I've tried restarting MakeMKV, rebooting, disconnecting and reconnecting the drive, even giving it hours unplugged, and updating to Sequoia 15.6. The DVD is region 1 and plays fine in DVD Player app on same drive. The only thing unusual is I'm having to use homebrew faketime to run, but it was working, then suddenly not, in the same and all subsequent instances.
This happened once before yesterday as I was attempting to start a parallel instance to image a disc while another's content was being extracted. I had given up trying to run two instances and waited for the extraction to complete. After that, it was happy to work as normal. I had not noticed the particular error, only the errors that followed it were the same.
OS device name: /dev/rdisk45
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 77
Firmware version: 1.03
Do I dare try to re-flash the drive with the same firmware it is already running? or just give it a day to resolve itself?
Post by dcoke22 » Sun Aug 10, 2025 1:46 pm
I'm not sure what error you're getting.
Whatever it is, I don't think you need to reflash your drive.
GJamesB
Post by GJamesB » Sun Aug 10, 2025 11:55 pm
Here's a debug log of the attempt today. On a hunch, I have tried a different USB-C port, but no dice. Thinking of attempting a reinstall of MakeMKV.
MakeMKV v1.18.1 darwin(arm64-release) started
Debug logging enabled, log will be saved as /Users/gjames/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MO8N95D2829d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Backing up disc into folder "/Users/gjames/Movies/backup/E1994.iso"
DEBUG: Code 0 at uko]hL;d*uzT{fk%_:29394781
DEBUG: Code 0 at uko]hL;d*uzT{fk%_:29395241
Drive BD-RE HL-DT-ST BD-RE BU40N 1.03 MO8N95D2829 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 1140851763 at %?F(jAvQNJ=d=T:121273020
DEBUG: Code 0 at %?F(jAvQNJ=d=T:29400071
DEBUG: Code 24 at W[0,!R|(C#JAe6:121261727
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
Calculated BUP offset for VTS #1 does not match one in IFO header.
DEBUG: Code 1 at %?F(jAvQNJ=d=T:29400071
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Calculated BUP offset for VTS #2 does not match one in IFO header.
DEBUG: Code 2 at %?F(jAvQNJ=d=T:29400071
DEBUG: Code 2 at %?F(jAvQNJ=d=T:121262210
DEBUG: Code 0 at ;\f9Dh7b>Bve'k/3P:121263245
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '38912'
Calculated BUP offset for VTS #3 does not match one in IFO header.
DEBUG: Code 3 at %?F(jAvQNJ=d=T:29400071
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 3 at %?F(jAvQNJ=d=T:121262210
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '38912'
Calculated BUP offset for VTS #4 does not match one in IFO header.
DEBUG: Code 4 at %?F(jAvQNJ=d=T:29400071
IFO file for VTS #4 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 4 at %?F(jAvQNJ=d=T:121262210
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '45056'
Calculated BUP offset for VTS #5 does not match one in IFO header.
DEBUG: Code 5 at %?F(jAvQNJ=d=T:29400071
IFO file for VTS #5 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_06_1.VOB' at offset '40960'
Calculated BUP offset for VTS #6 does not match one in IFO header.
DEBUG: Code 6 at %?F(jAvQNJ=d=T:29400071
DEBUG: Code 6 at %?F(jAvQNJ=d=T:121262210
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_07_1.VOB' at offset '0'
Calculated BUP offset for VTS #7 does not match one in IFO header.
DEBUG: Code 7 at %?F(jAvQNJ=d=T:29400071
IFO file for VTS #7 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 7 at %?F(jAvQNJ=d=T:121262210
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '38912'
DEBUG: Code 38 at Mt)F~ruH.8z~MjtaLzT:213133480
DEBUG: Code 117572073 at (j29=?}LKk\Ph$Ofy5:29394459
Error 'Internal error - Input parameter is incorrect (489)' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '38912'
DEBUG: Code 117572073 at (j29=?}LKk\Ph$Ofy5:213131502
DEBUG: Code 117572073 at %?F(jAvQNJ=d=T:213136907
DEBUG: Code 8 at %?F(jAvQNJ=d=T:213130053
Calculated BUP offset for VTS #8 does not match one in IFO header.
DEBUG: Code 101019395 at (j29=?}LKk\Ph$Ofy5:121263429
DEBUG: Code 101019395 at (j29=?}LKk\Ph$Ofy5:121262302
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_08_1.VOB' at offset '49152'
DEBUG: Code 48 at Mt)F~ruH.8z~MjtaLzT:213133480
DEBUG: Code 117572073 at (j29=?}LKk\Ph$Ofy5:121263429
DEBUG: Code 117572073 at (j29=?}LKk\Ph$Ofy5:121262302
Error 'Internal error - Input parameter is incorrect (489)' occurred while reading 'BD-RE HL-DT-ST BD-RE BU40N 1.03 MO8N95D2829' at offset '49152'
DEBUG: Code 8 at %?F(jAvQNJ=d=T:29400232
IFO file for VTS #8 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 8 at %?F(jAvQNJ=d=T:121262210
DEBUG: Code 0 at ;\f9Dh7b>Bve'k/3P:213131134
Calculated MVOB offset for VTS #0 does not match one in IFO header.
Calculated TVOB offset for VTS #1 does not match one in IFO header.
DEBUG: Code 0 at 9eS$innFdFOuvjlCt~9d:121266097
DEBUG: Code 233 at Fn6dMCYdm535DF1Xy9z6rDBj:0
DEBUG: Code 233 at AQ7Xo/dOTi79lJ4cbezwkPZA:0
DEBUG: Code 233 at Tk6yG2vvHbrvI3PisIMovyWh:0
DEBUG: Code 233 at d2uKc6BJTpeAF5QuKigaAtci:0
DEBUG: Code 233 at nD1Gn83GovOm+Lbq1MtcmlH7:0
DEBUG: Code 233 at GilgetsV90fW8Oa4xgtPf8E8:0
DEBUG: Code 233 at mreRkxzuT/GXqBx68vkoToZZ:0
DEBUG: Code 233 at MotxnpzvNJE6cSCHUQEYAa5k:0
DEBUG: Code 233 at 5NJ/PB7yzII6GsaWro1oXvog:0
DEBUG: Code 233 at h7fuvrxdVklROeZxURqtUTvq:0
DEBUG: Code 233 at 3aG79hyecqUnpTdnZyd5mcE/:0
DEBUG: Code 233 at oSvqrV684OI+iW3GgG1Uz/+X:0
DEBUG: Code 233 at v+Kx2ykbXLk+UQStNPa035b5:0
DEBUG: Code 233 at 1IRuGOI9tYR7nkuPyLT2kza5:0
DEBUG: Code 233 at 7eAJERxkH6HQDtBBJxbEl/GE:0
DEBUG: Code 233 at LgdcLxsBVbr917h3GHiCETUG:0
DEBUG: Code 233 at kiiOnAunPPFvJDw5S7sX3ZmP:0
DEBUG: Code 233 at xc4Piq/WE2M4PLyDof9XLmoY:0
DEBUG: Code 233 at fkgOzNVanKPREMXVV5IqEasS:0
DEBUG: Code 233 at kC6Fxw1MqG3+TGwI7EyjZ51i:0
DEBUG: Code 233 at xT0xkfImI9QonAoQqEfgBTcb:0
DEBUG: Code 233 at QqwhnhFWykvrHxogagfIclP6:0
DEBUG: Code 233 at f2Kj1JV/afggggJB8BBA7Ood:0
DEBUG: Code 233 at NOr+GHex/vpE9Uscf3XDxENb:0
DEBUG: Code 233 at HMJov5RZTm6yEwsfuIyZL4ib:0
DEBUG: Code 233 at uMu2xOMWvx8vU+2HTh9gjFvd:0
DEBUG: Code 233 at UHnhVI/upnTzv8ezc371+t+X:0
DEBUG: Code 233 at JClpN79oAZOYMARrGCpCt5tB:0
DEBUG: Code 233 at wESWamo8ulnsd3SW25dn8ap4:0
DEBUG: Code 233 at pNvwQjDKqSmH3rMmA8sQl5QR:0
DEBUG: Code 233 at FeuFs9VuuGHfhqNTS7mLlMCF:0
DEBUG: Code 233 at 1ZYdsFztQbah6kF/PSRc2Yl7:0
DEBUG: Code 233 at 5gAOxN2DfXeEVCp/+QWp9TuD:0
DEBUG: Code 233 at l+cJkbukXKf18PlnN/HNoCxD:0
DEBUG: Code 233 at YIoQW5xW4K7IFwg/r6kg7Pzc:0
DEBUG: Code 233 at +xA9pNTeQkRgasZNLyD4wS/O:0
DEBUG: Code 233 at w3UPkdCbqan36o7Eq/vs/RPu:0
DEBUG: Code 233 at gZgdlixcQIqyWDoKBhaOBq3E:0
DEBUG: Code 233 at 2I+LWsXzFD0C5Lf7tpyksh18:0
DEBUG: Code 233 at s09OwsUlWrfaFko/PgKRM3Zq:0
DEBUG: Code 233 at iBCZdoT7mATDV+QRkHeH/gzr:0
DEBUG: Code 233 at JyMnARaONljCVr4VMALExjGt:0
DEBUG: Code 233 at 6ythhNAk4nQjDWmzfM+QrzsP:0
DEBUG: Code 233 at VW8J6W/+qD4ZBo3xvWTbgzqR:0
DEBUG: Code 233 at 1z/iRY0N1rBIq8DcPknJIloy:0
Backup failed
Post by MartyMcNuts » Mon Aug 11, 2025 2:34 am
GJamesB wrote: Sun Aug 10, 2025 11:55 pm Here's a debug log of the attempt today. On a hunch, I have tried a different USB-C port, but no dice. Thinking of attempting a reinstall of MakeMKV.
Backup failed
With what's happening at the moment, I would not be uninstalling MakeMV just in case you can't get it running again!!
GJamesB
Post by GJamesB » Wed Aug 13, 2025 11:42 am
Well I did try reinstalling from the originally downloaded installer, and no luck.
But the new registration key seems to have solved the issue (thank you). This would seem to indicate that faketime is not the cure-all solution to an expired key for macOS users.
