1.17.6 DMG is Damaged
suchdisc
Post by suchdisc »
“makemkv_v1.17.6_osx.dmg” is damaged and can’t be opened. You should move it to the Trash.
I get this error no matter what troubleshooting steps I try, including downloading with different browsers and attempting to extract the data within the disk image using a third-party utility rather than the native macOS disk image mounter.
I'm on an M2 Pro 16" MacBook Pro running macOS Sonoma 14.2.1.
Just a heads up to the dev that the DMG needs to be remade and reuploaded.
morbius
Re: 1.17.6 DMG is Damaged
Post by morbius »
I suppose it could have been repaired in the last few hours, I just installed 1.17.6 cleanly on my M2 Air Sonoma 14.3.
luckystars
Post by luckystars »
This could be a downlaod issue.
I just tried to install MakeMKV on top of a clean install of Mac OS Mavericks (something I've had no issue with before).
Every version I tried off the main site had the same issue – downloadng with Firefox.
Solution was to use a dedicated download app.
Leech (which works with legacy Macs) worked perfectly first time.
Did the file you downloaded hash the same as the hash posted on MakeMKV.com?
https://makemkv.com/download/
luckystars
Didn't check sorry
