ASUS BD-12D1S-U external drive with pioneer bdr-209
Re: ASUS BD-12D1S-U external drive with pioneer bdr-209
theformat wrote:
Sat Jun 29, 2024 10:58 pm
Coopervid wrote:
Tue Jun 25, 2024 4:46 pm
cdan1980 wrote:
Tue Jun 25, 2024 6:18 am
Hi Coopervid,
I have the same model as the other users in this thread. I purchased a license for MakeMKV but this forum doesn't allow new registrants with a low post count to initiate PMs.
Could you kindly send me a PM and I will respond promptly with the complete MakeMKV info. Thanks for offering to help us!
Please copy & paste your Makemkv information here (just the text from the status). You are not yet allowed to send PMs therefore that doesn't work.
Hello Coopervid, I am in the same boat as cd1980 and cannot post a PM to you with my Drive Information.
My drive is currently in its OEM ASUS Enclosure. Are you able to help me out as well? Below is my drive info. Thank you for the assistance you have offered to others!!
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: [Redacted]
Firmware date: 2013-09-10
Highest AACS version: 76
Drive platform: RS8600
Firmware version: E401/ID44
The sluggishness of this board is unbearable!!! Read your PM.
theformat
Post by theformat »
Coopervid wrote:
Sun Jun 30, 2024 6:56 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Coopervid, Thank you very much! This is amazing! You've breathed new life into a drive I thought was only good for regular BluRays! You're the best!
yackov_bd
Post by yackov_bd »
Hello Coopervid, I Have the same drive as OP "theformat", and I was wondering if I can get some help please!
yackov_bd wrote:
Wed Jul 24, 2024 12:07 am
Please post your Makemkv info. I need to see your "drive platform".
yackov_bd
Post by yackov_bd »
This is the info from Makemkv:
Información de unidad de disco
Nombre del SO del dispositivo: /dev/sr1
Fabricante: ASUS
Producto: BW-12D1S-U
Revisión: E402
Número de serie: [redacted]
Fecha del firmware: 2018-01-15
Marcas de cifrado bus: 1B
Firmware version: E402/ID44
yackov_bd
Post by yackov_bd »
Coopervid wrote:
Wed Jul 24, 2024 9:08 am
I posted the info in the previous post, just think it didn't reach you Coopervid.
Hi Coopervid,
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Read your PM.
yackov_bd
Post by yackov_bd »
Coopervid wrote:
Thu Jul 25, 2024 9:20 am
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Read your PM.
Nop, I don't have any message from you. :(
yackov_bd wrote:
Thu Jul 25, 2024 5:10 pm
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Read your PM.
Now you have. I must have missed you.
renako
Post by renako »
I have Asus BD-12D1S-U with Pioneer bdr-208 fw. Is there anything that can be done to make it work to recognize UltraHD discs?
The info from MakeMKV are following:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Serial number: xxxxxxxxx
Firmware date: 2013-02-25
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: E301/ID71
renako wrote:
Sun Jul 28, 2024 2:12 am
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Read your PM.
renako
Post by renako »
Coopervid,
thank you very very much for your PM!
The drive has a UHD support now.
FYI, it worked directly, no need for 2 steps process; with the OEM enclosure connected through a USB cable to the PC.
renako
Post by renako »
I have another Asus BW-12D1S-U which seems to have Pioneer drive. It reads, plays, and writes blu-ray discs.
Is there anything that can be done to make this one to recognize UltraHD discs?
The profile info from MakeMKV are following:
OS device name: N:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Firmware date: 2011-05-06
Highest AACS version: 81
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1030
Firmware version: ID71
Note:
I noticed that Asus has a BW-16D1X-U FW Updater, Version E102, 2018/04/17, on its support website for its newer model BW-16D1X-U (which has either a LG or Pioner drive inside now). Is there a possibility that FW could be used on Pioneer platform RS1030 as well?
https://www.asus.com/us/motherboards-co ... BW-16D1X-U
renako wrote:
Tue Aug 06, 2024 3:33 am
I have another Asus BW-12D1S-U which seems to have Pioneer RS1030 drive inside. It reads, plays, and writes blu-ray discs.
OS device name: N:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Note:
I noticed that Asus has a BW-16D1X-U FW Updater, Version E102, 2018/04/17, on its support website for its newer model BW-16D1X-U (which has either a LG or Pioner drive inside now). Is there a possibility that FW could be used on Pioneer RS1030 as well?
No. This hardware is too old.
sohsume
Post by sohsume »
Hi Cooper,
I seem to have the same drive as lots of people. Any assistance is greatly appreciated to read UHD discs.
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number: [redacted]
Thanks again!
