Getting error when trying to rip Starship Troopers 4k steel book
peachyplant
Post by peachyplant » Sat Jul 27, 2024 7:40 pm
I am able to open the DVD and get to the selection screen after about 15 minutes into the rip it errors. I double checked the disc and there are no obvious scratches any suggestion would help also I can provide screenshots if needed
Re: Getting error when trying to rip Starship Troopers 4k steel book
Post by Woodstock » Sat Jul 27, 2024 9:52 pm
No need for screen shots, just log entries. The log says what MakeMKV saw.
peachyplant
Post by peachyplant » Sun Jul 28, 2024 1:17 am
Welp I started ripping the movie again to get the error code and it decided to work this time.
Post by Woodstock » Sun Jul 28, 2024 2:41 am
A lot of temporary errors can happen. A common one is if the disk spins faster than the drive has power for... and having a very fast write capability can hit that. You'll see it as errors about the drive going off-line. Slow it down just a bit, say, if the hard drive is busy with more than one thing going on at a time, and things suddenly (and mysteriously) work.
If that was what happened, you may get this on another disk. Just remember to keep track of the log.
poly888
Post by poly888 » Sun Jul 28, 2024 7:55 am
The good old "Did you try to turn it off and on again?" saved the day again
