Post by RESET_9999 » Thu Jul 25, 2024 4:23 pm
the best trackers dont let people in for money.
You need to get invited by someone already in but I believe they are sometimes recruiting users from other private trackers so you might be lucky if you are on one of those trackers...
https://www.reddit.com/r/trackers/
Vault
Post by Vault » Thu Jul 25, 2024 5:15 pm
Hi all, digging a little bit here (nearly 4 years :D ) to update the infos I have.
shawnc22 wrote:
Thu Dec 24, 2020 5:03 pm
When you’re doing conversions from a UHD disc to single layer, you’re going to lose data (neglible in MEL). There is currently not a lossless way from converting from double to single layer where the info in the EL is reencoded into the BL; any info in the EL is just being discarded.
Vault wrote:Like MastaG I was hoping for a 1:1 experience paradise, when I read a few weeks ago that MKV + DV was live.
But I understand (thanks to you + contributors) that YTD it remains a lossy process, even using 1.15.4.
So: is it possible YTD to convert a UHD disc and/or ISO, to a single layer MKV?
I still mean exactly in 1:1, e.g full AV streams with no data loss - at all.
Because Option 2 is, I know: to buy a Pannde PD6x - or a Magnetar 900.
Which is beside the fact that I don't need Blu-ray menus, out of my league :(
texwatson
Post by texwatson » Sat Jul 27, 2024 1:52 am
valington wrote:
Thu Jul 25, 2024 7:37 am
RESET_9999 wrote:
Mon Jul 22, 2024 10:58 am
i dont remember
Reset please advice torrent trackers with good seeding
Usenet everyday and twice on sunday...
tpicnic05
Post by tpicnic05 » Sat Jul 27, 2024 2:58 am
Please don't burn me for this question but I just want to make sure I'm following this all correctly.
I have a Ugoos am6b+ with CoreELEC installed. I've ripped all my 4K blu ray movies with MakeMKV and I have done nothing to those ripped files so I play them back as MakeMKV has made them.
Do I need to do anything extra to get the full FEL CMV2.9 (I think that's correct?) that would be played on a 4k blu ray player? I've seen some posts around suggesting to rip as MP4 or other file types so I just want to see if I need to redo some work on my Dolby Vision blu ray rips.
LV8HD
Post by LV8HD » Sun Jul 28, 2024 9:37 am
@RESET_9999 I measured HDR10 to get MaxCLL and MaxFALL metadata using madVR and excluding black bars to get a more accurate MaxFALL value, but when I open the measurement file with madMeasurementAnalyzer it gives me a different MaxFALL than the plot. Which on should I trust?
poly888
Post by poly888 » Sun Jul 28, 2024 10:03 am
This is the first time I hear about such system, why wouldn't a pay version be good? I mean you give money for access no?
Post by RESET_9999 » Sun Jul 28, 2024 12:30 pm
i dont know
kazuma
Post by kazuma » Sun Jul 28, 2024 4:33 pm
Does nobody have a invite for BHD? What is the website?
deadchip12
Post by deadchip12 » Wed Jul 31, 2024 1:50 pm
I wonder why the subtitles of 4k hdr films are super bright when I watch it on the sony x700 (for which I have to manually extract the subtitles and lower their brightness using external software), but now on the ugoos am6b+ they are appropriately bright.
Rororororo
Post by Rororororo » Thu Aug 01, 2024 9:25 pm
@RESET_9999
just checking 3.0.0, what does it mean and why is it bad (red)
1st Frame is a Scene Cut: YES (good)
Consecutive Scene Cuts: YES
Base Layer: ICtCp (DoVi P5)
Edit:
ok got it "D/SC_Flag=F" is old 2-1-1 to fix it
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Post by RESET_9999 » Thu Aug 01, 2024 11:36 pm
it's just a warning. Dont edit it if it's from a retail source.
This is for the old P8 hybrid remux when we were not duplicating or removing frames correctly as explained here:
viewtopic.php?p=155652#p155652
Rororororo
Post by Rororororo » Fri Aug 02, 2024 3:18 am
This is actually from such P8 remuxes, I was checking some
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
Arq231
Post by Arq231 » Fri Aug 02, 2024 12:28 pm
How to fix the RPU mismatch problem? the last frame in most of the cut-scenes has different brightness than the cut-scene itself.
I'm unable to import the movie into Resolve directly in its RAW format. However, I'm able to when I trim it using ffmpeg to keep its properties unchanged otherwise it would lose its HDR format.
I would like to convert this movie into SDR Dolby Vision.
Any suggestions?
Here are the movie properties:
Format                         : Matroska
Format version                 : Version 4
File size                      : 43.3 GiB
Duration                       : 1 h 31 min
Overall bit rate mode          : Variable
Overall bit rate               : 67.7 Mb/s
Frame rate                     : 23.976 FPS
Movie name                     : Rocky.IV.1985.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.5.1-FGT
Encoded date                   : 2023-02-28 07:33:24 UTC
Writing application            : mkvmerge v74.0.0 ('You Oughta Know') 64-bit
Writing library                : libebml v1.4.4 + libmatroska v1.7.1
Video
ID in the original source medi : 4113 (0x1011)
Format                         : HEVC
Format/Info                    : High Efficiency Video Coding
Format profile                 : Main 10@L5.1@High
HDR format                     : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                       : V_MPEGH/ISO/HEVC
Bit rate                       : 58.9 Mb/s
Width                          : 3 840 pixels
Height                         : 2 160 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 (24000/1001) FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0 (Type 2)
Bit depth                      : 10 bits
Bits/(Pixel*Frame)             : 0.296
Stream size                    : 37.6 GiB (87%)
Language                       : English
Default                        : No
Forced                         : No
Color range                    : Limited
Color primaries                : BT.2020
Transfer characteristics       : PQ
Matrix coefficients            : BT.2020 non-constant
Mastering display color primar : Display P3
Mastering display luminance    : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level    : 3992 cd/m2
Maximum Frame-Average Light Le : 1649 cd/m2
Original source medium         : Blu-ray
XML file last entries:
            <Record>
              <In>120488</In>
              <Duration>56</Duration>
            </Record>
            <PluginNode>
              <DolbyEDR level="1">
                <ImageCharacter>0.0004884005,0.22857143,0.63565326</ImageCharacter>
              </DolbyEDR>
              <DolbyEDR level="2">
                <TID>1</TID>
                <Trim>0,0,0,0,0,-0.063356996,0,0.08154297,0</Trim>
              </DolbyEDR>
            </PluginNode>
          </Shot>
        </Track>
      </Video>
    </Output>
  </Outputs>
</DolbyLabsMDF>
Post by RESET_9999 » Fri Aug 02, 2024 6:27 pm
just look on the Resolve media page, and you will find the framecount of the prores file.
Then in the xml, modify the duration of the last shot(probably just 57 or 55) to match that framecount.
Rororororo
Post by Rororororo » Fri Aug 02, 2024 7:08 pm
some combination in the new MODE.I (1) in 3.0.0/3.0.1 seems not to work like "DF", the section with options is a bit confusing and could be a bit more readable, also what are valves v and 7?
*You can select more than one value(except: e/m/p/s/7/v) but no space between values: EG: 569r4 (default= Exit)
L5=5/L6=6/L9=9/Resync=R or D/SC_Flag=F/RemCMV4=4 - /PLOT=P/CheckSync=S/Read=E/Metafier=M/Exit=X
DF
Processing "Thor The Dark World (November 2013) 4K DV8_RPU - Copy.bin"
Exporting Scene cuts...
Parsing RPU file...
Exporting scenes list...
Done.
Check "G:\dovi\3.0.0\Thor The Dark World (November 2013) 4K DV8_RPU - Copy_scene-cuts.txt" and select if you have to add or remove a refresh flag(s)...
Do you want to add or remove scene_refresh_flag? choices are Add=a and Remove=r and press enter...
a
Which frames do you want to add a scene cut flag? (inclusive, default=0 1st frame)
Adding a Scene Cut flag at frame 0
Done.
1 file(s) copied.
Deleting TEMP folder...
The script has been completed. Do you want to quit or go back to main menu (q or m default=q)?
edit:
some other bugs, clicking any button at the end after extracting RPU from the stream, starts the extraction process again
ASUS BW-16D1HT 3.10
Ugoos AM6B Plus
