Is my Asus BW-16D1HT flashable?
JarrodS
#1 Post by JarrodS » Fri Jul 26, 2024 8:14 pm
Do I need to take it out of my computer to check the build date? Or is the below suggestion that it's possible always reliable? According to my records I purchased it in the second half of 2016. If this is an older drive, I'll brick it if I flash, right? Not even sure I want to rip my 4K discs but it might be handy and I already own the drive.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: [redacted]
Bus encryption flags: 1F
Highest AACS version: 48
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Re: Is my Asus BW-16D1HT flashable?
#2 Post by d00zah » Sat Jul 27, 2024 12:20 am
The guide says:
Asus BW-16D1HT on any Firmware directly to > Asus BW-16D1HT 3.10MK
JarrodS
#3 Post by JarrodS » Sat Jul 27, 2024 1:33 am
I was able to successfully flash the -MK firmware and am ripping my first UHD BD right now. Thanks to everybody who worked on this. Very impressive that my 8-yo drive is able to do this.
