Compatibility Regression - HTH
richwill
#1 Post by richwill » Thu Sep 08, 2011 3:23 pm
I reported an issue with ripping The Tourist. Here is the debug log below from 1.6.8:
Debug log started at Fri May 6 11:25:57 2011 , written by MakeMKV v1.6.8 linux(x64-release)
001005:0000 MakeMKV v1.6.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/xxxx/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at NFg[E26Gz-%oQ}i#28]Y=Hj:213129984
DCE=iYu211KuzLDygofd+w5K6L/XD5Zep5IrKc7Gtt70siLfIhIapN+OlT+oQlZ6EH2P/CFMfqOQMRxL2iW8OpM7Y1heDPEt2Ozus0knzqD3rhdXuGWO/46XZkn6GJbdgo83hkb1kqvxghPf5fUCd8F40MP+rb9pQI0j0A==
DISCID=2294D4DC7DC172AC15481A979BA718C88976A5B7
001003:0020 DEBUG: Code 1073741829 at J!>RolwKwA^TB>]K:29393953
003307:0000 File 00099.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003025:0000 Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00095.mpls is equal to title 00099.mpls and was skipped
003309:0000 Title 00096.mpls is equal to title 00099.mpls and was skipped
003025:0000 Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00105.m2ts was added as title #2
003307:0000 File 00106.m2ts was added as title #3
003307:0000 File 00107.m2ts was added as title #4
003307:0000 File 00108.m2ts was added as title #5
003307:0000 File 00109.m2ts was added as title #6
003307:0000 File 00110.m2ts was added as title #7
003025:0000 Title #00111.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00117.m2ts was added as title #8
003307:0000 File 00118.m2ts was added as title #9
003307:0000 File 00119.m2ts was added as title #10
003307:0000 File 00120.m2ts was added as title #11
003307:0000 File 00121.m2ts was added as title #12
005014:0000 Saving 1 titles into directory /media/Silver Box 1
Below is the debug log after reverting to 1.6.5 and the same disk:
Debug log started at Thu Sep 8 13:58:08 2011 , written by MakeMKV v1.6.5 linux(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.6.5 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/rich/MakeMKV_log.txt
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command 46020..00140 to device 'SG:dev_11:2'
001003:0020 DEBUG: Code 0 at y8qlJYE=\|"Yz4gz:121269156
005014:0000 Saving 1 titles into directory /media/Silver Box 1/BR/Movies
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
I have tried multiple versions since, and nothing beyond 1.6.5 works for me, and I get the same results with all BR disks I've tried.
Drive used is: LG BH10NS30 with H102 Firmware.
Re: Compatibility Regression - HTH
#2 Post by mike admin » Thu Sep 22, 2011 9:52 am
Do you have any problems with 1.6.15?
