Asus BW-16D1H-U Pro
Asus BW-16D1H-U Pro
Hi, I am new to this forum.
I have an MKV license and just purchased an Asus. I would like to extend it to become a LibreDrive to open 4K UHD disks.
I want to use it with a Mac on the latest OS, but I also have a Win 10 laptop for execution if necessary.
From below MKV info this should be possible?
Can you help?
What does it cost?
Can I do it myself?
Best regards, Buldre
Norway
MKV info with BD inserted:
OS device name: /dev/rdisk2
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: —
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
Can you help?
What does it cost?
Can I do it myself?
Norway
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: —
Re: Asus BW-16D1H-U Pro
Email me for the flasher.
You will need to use windows
Send that info to me in the email
It's $25
It's $25
stoffel010170
Hi
is it only possible to flash the device under Windows?
KR
Stefan
KR
Stefan
No pioneers can not be flashed on Linux VMS varry I recommend you use windows and email me for the auto flasherstoffel010170 wrote: Tue Nov 19, 2024 12:50 pm Hi
KR
Stefan
Which firmware for the ASUS BW-16D1H-U PRO please ? I also have issue with Nero Burning rom (a better software ?) which doesn’t detect my device
maybe need a driver I don’t have, just the default Windows one.
Thanks.
Thanks.
- IMG_3443.png (39.64 KiB) Viewed 9286 times
See guide below or email me or MartyMaskman wrote: Sun Mar 29, 2026 10:36 pm Hi,
Which firmware for the ASUS BW-16D1H-U PRO please ? I also have issue with Nero Burning rom (a better software ?) which doesn’t detect my devicemaybe need a driver I don’t have, just the default Windows one.
Thanks.
For an automated flasher
That's an lg drive not pioneer
can I flash this drive?
Laufwerksinformation
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: DVD-ROM
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Serienummer: TFDL026755WL
Firmware-Datum: 2019-03-07
Highest AACS version: 68
Firmware version: E115/ID71
I know that RS8F00 is not flashable via the SDFTOOL. Any workaround? I really do not ant to brick my drive.
Thx a lot
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
Sure email me that drive info section see below for emailPerez wrote: Mon Aug 03, 2026 4:42 pm Hi,
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
I have an automated flasher for it
PM sent.Perez wrote: Mon Aug 03, 2026 4:42 pm Hi,
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
Coopervid wrote: Tue Aug 04, 2026 9:12 amPM sent.Perez wrote: Mon Aug 03, 2026 4:42 pm Hi,
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
Thx @ Coopervid!
My drive will now be displayed this way
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-S12U
Revision: 1.02
Firmware-Datum: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
4K Blurays can now be ripped? (not played... i know)
Ripped and played if you activate integration for VLC in Makemkv.
okay, was was just confused, because the firmware is still marked as "unpatched" and I thought it should be displayed as patched when UHD was activated.Coopervid wrote: Wed Aug 05, 2026 3:46 pm Ripped and played if you activate integration for VLC in Makemkv.
I still have to check the integration for VLS in Makemakv (formally used DVDFab), but together with handbrake MakeMKV seems to be really great.
No. All Pioneer firmware is original so will never say patched. Only the some of the MT1959 firmware are patched. MK = MakeMKV patched firmware.Perez wrote: Wed Aug 05, 2026 4:09 pmokay, was was just confused, because the firmware is still marked as "unpatched" and I thought it should be displayed as patched when UHD was activated.Coopervid wrote: Wed Aug 05, 2026 3:46 pm Ripped and played if you activate integration for VLC in Makemkv.
