Asus BW-16D1H-U Pro
Buldre
Asus BW-16D1H-U Pro
Post by Buldre »
Hi, I am new to this forum.
I have an MKV license and just purchased an Asus. I would like to extend it to become a LibreDrive to open 4K UHD disks.
I want to use it with a Mac on the latest OS, but I also have a Win 10 laptop for execution if necessary.
From below MKV info this should be possible?
Can you help?
What does it cost?
Can I do it myself?
Best regards, Buldre
Norway
MKV info with BD inserted:
OS device name: /dev/rdisk2
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: —
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F00
Firmware version: E116/ID71
Re: Asus BW-16D1H-U Pro
Email me for the flasher.
You will need to use windows
Send that info to me in the email
It's $25
Buldre
Post by Buldre »
Thanks! :D
Buldre
Post by Buldre »
Worked super!
stoffel010170
Post by stoffel010170 »
Hi
is it only possible to flash the device under Windows?
KR
Stefan
stoffel010170 wrote: Tue Nov 19, 2024 12:50 pm Hi
KR
Stefan
No pioneers can not be flashed on Linux VMS varry I recommend you use windows and email me for the auto flasher
Maskman
Post by Maskman »
Which firmware for the ASUS BW-16D1H-U PRO please ? I also have issue with Nero Burning rom (a better software ?) which doesn’t detect my device :? maybe need a driver I don’t have, just the default Windows one.
Thanks.
Maskman wrote: Sun Mar 29, 2026 10:36 pm Hi,
Thanks.
See guide below or email me or Marty
For an automated flasher
That's an lg drive not pioneer
Perez
Post by Perez »
can I flash this drive?
Laufwerksinformation
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: DVD-ROM
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Serienummer: TFDL026755WL
Firmware-Datum: 2019-03-07
Highest AACS version: 68
Firmware version: E115/ID71
I know that RS8F00 is not flashable via the SDFTOOL. Any workaround? I really do not ant to brick my drive.
Thx a lot
Perez wrote: Mon Aug 03, 2026 4:42 pm Hi,
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
Sure email me that drive info section see below for email
I have an automated flasher for it
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
PM sent.
Perez
Post by Perez »
Coopervid wrote: Tue Aug 04, 2026 9:12 am
Produzent: ASUS
Produkt: BW-16D1H-U
Revision: E115
Thx a lot
PM sent.
Thx @ Coopervid!
My drive will now be displayed this way
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-S12U
Revision: 1.02
Firmware-Datum: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
4K Blurays can now be ripped? (not played... i know)
Ripped and played if you activate integration for VLC in Makemkv.
Perez
Post by Perez »
Coopervid wrote: Wed Aug 05, 2026 3:46 pm Ripped and played if you activate integration for VLC in Makemkv.
okay, was was just confused, because the firmware is still marked as "unpatched" and I thought it should be displayed as patched when UHD was activated.
I still have to check the integration for VLS in Makemakv (formally used DVDFab), but together with handbrake MakeMKV seems to be really great.
Perez wrote: Wed Aug 05, 2026 4:09 pm
No. All Pioneer firmware is original so will never say patched. Only the some of the MT1959 firmware are patched. MK = MakeMKV patched firmware.
