Kevin_28
Re: SDFtool Flasher
#1081 Post by Kevin_28 » Tue Jul 23, 2024 2:48 am
MartyMcNuts wrote: Tue Jul 23, 2024 2:18 am
Kevin_28 wrote: Tue Jul 23, 2024 12:43 am
MartyMcNuts wrote: Mon Jul 22, 2024 10:31 pm You need to use the recovery option for the crossflash. Follow the gif in the first post of this thread.
Hi there! Thanks for responding and helping me out. I should have mentioned earlier in my initial post that I used write to update to 1.03 and recovery for the crossflash as per the instructions.
So you're all good then?
Unfortunately, no. My initial post was made with the update instructions assumed. it says, "Done successfully, please wait.", but I am unable to play any 4k disks and I don't see that version reflected on MakeMKV nor the SDFtool Flasher.
Re: SDFtool Flasher
#1082 Post by MartyMcNuts » Wed Jul 24, 2024 12:33 am
Kevin_28 wrote: Tue Jul 23, 2024 2:48 am
If that's the case, then you are not following the instructions correctly.
Does MakeMKV show the drive on BP50NB40 1.03 or BU40N 1.00?
jinx100
Re: SDFtool Flasher
#1083 Post by jinx100 » Wed Jul 24, 2024 12:51 am
Marty's instructions are clear and he even includes an animation. It looks like you did the first step of writing the BP50NB40_NB50_1.03_MK binary but messed up the recovery step.
When you select "Recovery" a file selector dialog opens and you need to choose the BP50NB40_NB50_1.03_MK.bin binary again. Then, in the "Write" file selector dialog choose the BU40N_1.00.bin file. After you run this last step, your drive will appear to be a BU40N in Windows and MakeMKV.
Kevin_28
Re: SDFtool Flasher
#1084 Post by Kevin_28 » Wed Jul 24, 2024 4:19 pm
MartyMcNuts wrote: Wed Jul 24, 2024 12:33 am If that's the case, then you are not following the instructions correctly.
It shows the BP50NB40 1.03
jinx100 wrote: Wed Jul 24, 2024 12:51 am Marty's instructions are clear and he even includes an animation. It looks like you did the first step of writing the BP50NB40_NB50_1.03_MK binary but messed up the recovery step.
I did follow that animation when I started and selected BP50NB40 1.03 mk first then the BU40N on the recovery. No dice. It's OK. I'll try some other things and worst case I can always just purchase one. Not a big deal. Thanks for your help! I greatly appreciate it.
ThatPrimate
Re: SDFtool Flasher
#1085 Post by ThatPrimate » Wed Jul 24, 2024 11:54 pm
Hello, I've been working on this on and off for the past 3 week. I have a WP50NB40 drive with revision 1.03. When I run the flasher it says complete, but the reported firmware never seems to change. What should I be doing differently?
Something that I thought was a little curious was that the reported firmware date in MakeMKV is set for 2121-07-08 16:09. I don't know if this has anything to do with my efforts, but I at least thought it was an interesting date.
Re: SDFtool Flasher
#1086 Post by MartyMcNuts » Thu Jul 25, 2024 12:54 am
ThatPrimate wrote: Wed Jul 24, 2024 11:54 pm Hello, I've been working on this on and off for the past 3 week. I have a WP50NB40 drive with revision 1.03. When I run the flasher it says complete, but the reported firmware never seems to change. What should I be doing differently?
Follow the instructions in the first post of this thread. There's even a gif showing you what to do!
ThatPrimate
Re: SDFtool Flasher
#1087 Post by ThatPrimate » Thu Jul 25, 2024 1:08 am
MartyMcNuts wrote: Thu Jul 25, 2024 12:54 am
I've followed everything there, treating WP as BP. When I followed the steps, the firmware version never changed. I've done it twice to see if I missed something the first time, but nothing changed.
jinx100
Re: SDFtool Flasher
#1088 Post by jinx100 » Thu Jul 25, 2024 1:49 am
See more wisdom from Marty at: viewtopic.php?p=143155#p143155
iredmc
Re: SDFtool Flasher
#1089 Post by iredmc » Thu Jul 25, 2024 10:16 pm
Coopervid wrote: Thu Feb 23, 2023 10:30 pm Most likely your chip in the enlosure doesn't support flashing.
I am having this problem as well, and I'm not using an enclosure at all.
Re: SDFtool Flasher
#1090 Post by Coopervid » Fri Jul 26, 2024 9:46 am
iredmc wrote: Thu Jul 25, 2024 10:16 pm
You need to be more specific. Which drive and what type of connection are you using?
iredmc
Re: SDFtool Flasher
#1091 Post by iredmc » Fri Jul 26, 2024 9:16 pm
Coopervid wrote: Fri Jul 26, 2024 9:46 am
At first I tried USB 3 (via enclosure), but then I decided that was annoying and used SATA. The drive is an LG WH16NS40.
segfaulted
Re: SDFtool Flasher
#1092 Post by segfaulted » Tue Jul 30, 2024 4:35 am
@MartyMcNuts
I'm running into a tiny bug when starting the flasher GUI when I have disc drives present without an assigned drive letter.
This happens when I mount and then eject an iso file with Windows 10's built-in handler, which keeps Microsoft's virtual drive in the background after unmounting. Rebooting usually fixes this one.
The error can also come up when I manually unassign drive letters in Disk Management (diskmgmt.msc)
************** Exception Text **************
System.ArgumentOutOfRangeException: StartIndex cannot be less than zero. (Parameter 'startIndex')
   at System.String.Substring(Int32 startIndex, Int32 length)
   at SDFtool_Flasher_Updated.Form1.Get_Drive_List()
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
Re: SDFtool Flasher
#1093 Post by MartyMcNuts » Tue Jul 30, 2024 6:02 am
segfaulted wrote: Tue Jul 30, 2024 4:35 am @MartyMcNuts
Don't run the tool when messing with drive letters. When mounting/unnmounting ISO's also make sure the tool is not open. Close it until your drive letters are sorted then reopen it.
ryanb0517
Re: SDFtool Flasher
#1094 Post by ryanb0517 » Wed Jul 31, 2024 10:49 pm
I just got my LG WP50NB40 and I was wondering if this is the correct step to cross flash to DE_LG_BU40N_1.00.bin
1) WRITE FIRMWARE DE_LG_WP50NB40-NB50_1.03_MK.bin
2) RECOVER FIRMWARE DE_LG_WP50NB40-NB50_1.03_MK.bin
3) WRITE FIRMWARE DE_LG_BU40N_1.00.bin
I tried doing the following steps as instructed by someone else in another post but my player wont pick up my "The Martian" UHD disc. I hope I didn't f' up my new drive. Please help!
segfaulted
Re: SDFtool Flasher
#1095 Post by segfaulted » Thu Aug 01, 2024 2:43 am
ryanb0517 wrote: Wed Jul 31, 2024 10:49 pm I just got my LG WP50NB40 and I was wondering if this is the correct step to cross flash to DE_LG_BU40N_1.00.bin
If you're doing WRITE again to do a cross-flash, that probably won't work. In other words, your steps #2 and 3 look a bit off.
Use RECOVER mode. You'll point it to the current firmware file, which might be DE_LG_WP50NB40-NB50_1.03_MK.bin if UHD discs haven't worked in your drive. Then you can select the firmware that you want to flash, choose DE_LG_BU40N_1.00.bin
The drive's LED light should blink during the flashing process if you did it correctly. If it doesn't blink, the drive is ignoring the reflash.
You can check the drive info in MakeMKV to see if the reflash worked or not. The "Product" and "Revision" should match the firmware ID.
