Draco1544 wrote:
Fri Jul 19, 2024 5:08 pm
What is DEE.exe and how I can get it ?
https://professional.dolby.com/product/ ... ng-engine/
Quaid
Post by Quaid »
Awesome thread, been following since quietvoid shared his method. Recently grabbed Ugoos AM6B Plus and have been updating DV files in my library. Afew questions would really save me some time:
-I just started using Reset_9999's tools afew days ago, all my DV profile 8 files have been created with quietvoids old bat files, is there
any reasons to redo these profile 8 again with Reset_9999's tools since they are maintained/updated?
-I've been using 4-2 workflow with the new tools to create fel and it works really well but I cant workout how to choose which streams i want to encode instead of the whole .m2ts file - choose which audio, no subs etc.
-Is there a updated database somewhere that listed what UHD are FEL? so I know which films I have to update.
No, my ''tools'' are just scripts that use the same quietvoid's dovi_tool.exe
Or maybe you meant yusesope's old bat file (original method)? If your file works, I see no reason to remux them again with the newer dovi_tool.exe
dovi_scripts has a workflow to create ST-DL but it's not very useful/efficient because it has to mux to a hevc file with dovi_tool and then mux to MKV. It would be best/faster if you used MakeMKV(free in beta) or mkvtoolnix instead, because it can mux a BD to ST-DL straight to MKV and you can select any audio/subs.
viewtopic.php?t=1053
idk but dovi_scripts Workflow 2-2 can quickly find if any input is FEL or MEL.
Quaid
Post by Quaid »
Thanks for the reply and all the answers.
I did not realize I could just drop the .m2ts file in toolnix and it would export STDL file, working great!
deadchip12
Post by deadchip12 »
@RESET_9999 How do you get the dolby vision streaming version of Goodfellas? Can't find it anywhere.
i dont remember
FLarnhill
Post by FLarnhill »
RESET_9999 wrote:
Mon Jul 22, 2024 10:58 am
i dont remember
In your "grade master check" section on your Google Sheets, you listed encoders to avoid doing DV hybrids. Any opinions on DVSUX, TEPES, LEGiON, DVT, FraMeSToR (not MainFrame), HuN-TRiNiTY, and Flights? I know that's a lot, I had no idea this was a full fledged community.
valington
Post by valington »
i dont remember
Reset please advice torrent trackers with good seeding
my favorite tracker is BHD.
valington
Post by valington »
RESET_9999 wrote:
Thu Jul 25, 2024 11:03 am
How can i get there only for donation or how ?
the best trackers dont let people in for money.
You need to get invited by someone already in but I believe they are sometimes recruiting users from other private trackers so you might be lucky if you are on one of those trackers...
https://www.reddit.com/r/trackers/
Vault
Post by Vault »
Hi all, digging a little bit here (nearly 4 years :D ) to update the infos I have.
shawnc22 wrote:
Thu Dec 24, 2020 5:03 pm
When you’re doing conversions from a UHD disc to single layer, you’re going to lose data (neglible in MEL). There is currently not a lossless way from converting from double to single layer where the info in the EL is reencoded into the BL; any info in the EL is just being discarded.
Vault wrote:Like MastaG I was hoping for a 1:1 experience paradise, when I read a few weeks ago that MKV + DV was live.
But I understand (thanks to you + contributors) that YTD it remains a lossy process, even using 1.15.4.
So: is it possible YTD to convert a UHD disc and/or ISO, to a single layer MKV?
I still mean exactly in 1:1, e.g full AV streams with no data loss - at all.
Because Option 2 is, I know: to buy a Pannde PD6x - or a Magnetar 900.
Which is beside the fact that I don't need Blu-ray menus, out of my league :(
texwatson
Post by texwatson »
valington wrote:
Thu Jul 25, 2024 7:37 am
i dont remember
Usenet everyday and twice on sunday...
tpicnic05
Post by tpicnic05 »
Please don't burn me for this question but I just want to make sure I'm following this all correctly.
I have a Ugoos am6b+ with CoreELEC installed. I've ripped all my 4K blu ray movies with MakeMKV and I have done nothing to those ripped files so I play them back as MakeMKV has made them.
Do I need to do anything extra to get the full FEL CMV2.9 (I think that's correct?) that would be played on a 4k blu ray player? I've seen some posts around suggesting to rip as MP4 or other file types so I just want to see if I need to redo some work on my Dolby Vision blu ray rips.
LV8HD
Post by LV8HD »
@RESET_9999 I measured HDR10 to get MaxCLL and MaxFALL metadata using madVR and excluding black bars to get a more accurate MaxFALL value, but when I open the measurement file with madMeasurementAnalyzer it gives me a different MaxFALL than the plot. Which on should I trust?
