Quaid
#10171 Post by Quaid » Sun Jul 21, 2024 6:27 am
Thanks for the reply and all the answers.
I did not realize I could just drop the .m2ts file in toolnix and it would export STDL file, working great!
deadchip12
#10172 Post by deadchip12 » Mon Jul 22, 2024 9:25 am
@RESET_9999 How do you get the dolby vision streaming version of Goodfellas? Can't find it anywhere.
#10173 Post by RESET_9999 » Mon Jul 22, 2024 10:58 am
i dont remember
FLarnhill
#10174 Post by FLarnhill » Thu Jul 25, 2024 7:29 am
RESET_9999 wrote: Mon Jul 22, 2024 10:58 am i dont remember
In your "grade master check" section on your Google Sheets, you listed encoders to avoid doing DV hybrids. Any opinions on DVSUX, TEPES, LEGiON, DVT, FraMeSToR (not MainFrame), HuN-TRiNiTY, and Flights? I know that's a lot, I had no idea this was a full fledged community.
valington
#10175 Post by valington » Thu Jul 25, 2024 7:37 am
Reset please advice torrent trackers with good seeding
#10176 Post by RESET_9999 » Thu Jul 25, 2024 11:03 am
my favorite tracker is BHD.
valington
#10177 Post by valington » Thu Jul 25, 2024 3:53 pm
RESET_9999 wrote: Thu Jul 25, 2024 11:03 am my favorite tracker is BHD.
How can i get there only for donation or how ?
#10178 Post by RESET_9999 » Thu Jul 25, 2024 4:23 pm
the best trackers dont let people in for money.
You need to get invited by someone already in but I believe they are sometimes recruiting users from other private trackers so you might be lucky if you are on one of those trackers...
https://www.reddit.com/r/trackers/
Vault
#10179 Post by Vault » Thu Jul 25, 2024 5:15 pm
Hi all, digging a little bit here (nearly 4 years :D ) to update the infos I have.
shawnc22 wrote: Thu Dec 24, 2020 5:03 pm When you’re doing conversions from a UHD disc to single layer, you’re going to lose data (neglible in MEL). There is currently not a lossless way from converting from double to single layer where the info in the EL is reencoded into the BL; any info in the EL is just being discarded.
Vault wrote:Like MastaG I was hoping for a 1:1 experience paradise, when I read a few weeks ago that MKV + DV was live.
But I understand (thanks to you + contributors) that YTD it remains a lossy process, even using 1.15.4.
So: is it possible YTD to convert a UHD disc and/or ISO, to a single layer MKV?
I still mean exactly in 1:1, e.g full AV streams with no data loss - at all.
Because Option 2 is, I know: to buy a Pannde PD6x - or a Magnetar 900.
Which is beside the fact that I don't need Blu-ray menus, out of my league :(
texwatson
#10180 Post by texwatson » Sat Jul 27, 2024 1:52 am
valington wrote: Thu Jul 25, 2024 7:37 am
Usenet everyday and twice on sunday...
tpicnic05
#10181 Post by tpicnic05 » Sat Jul 27, 2024 2:58 am
Please don't burn me for this question but I just want to make sure I'm following this all correctly.
I have a Ugoos am6b+ with CoreELEC installed. I've ripped all my 4K blu ray movies with MakeMKV and I have done nothing to those ripped files so I play them back as MakeMKV has made them.
Do I need to do anything extra to get the full FEL CMV2.9 (I think that's correct?) that would be played on a 4k blu ray player? I've seen some posts around suggesting to rip as MP4 or other file types so I just want to see if I need to redo some work on my Dolby Vision blu ray rips.
LV8HD
#10182 Post by LV8HD » Sun Jul 28, 2024 9:37 am
@RESET_9999 I measured HDR10 to get MaxCLL and MaxFALL metadata using madVR and excluding black bars to get a more accurate MaxFALL value, but when I open the measurement file with madMeasurementAnalyzer it gives me a different MaxFALL than the plot. Which on should I trust?
poly888
#10183 Post by poly888 » Sun Jul 28, 2024 10:03 am
RESET_9999 wrote: Thu Jul 25, 2024 4:23 pm the best trackers dont let people in for money.
This is the first time I hear about such system, why wouldn't a pay version be good? I mean you give money for access no?
#10184 Post by RESET_9999 » Sun Jul 28, 2024 12:30 pm
i dont know
kazuma
#10185 Post by kazuma » Sun Jul 28, 2024 4:33 pm
Does nobody have a invite for BHD? What is the website?
