Use the force flash commandshipsofjw wrote: ↑Sun Jul 21, 2024 3:24 amMakeMKV is not showing any LibreDrive information for this drive. I am on the latest version of MakeMKV.MartyMcNuts wrote: ↑Sun Jul 21, 2024 12:20 amShow us the libredrive section below the section you posted above.hipsofjw wrote: ↑Sat Jul 20, 2024 5:43 amHey everyone,
I recently bought a slim external BU40N. I was under the impression that all these drives can be flashed to rip UHDs, so I'm a little surprised by the problems I've run into. I'm running Windows 11. Here are the drive details from MakeMKV:
OS device name: G:
Product: BD-RE BU40N
Revision: U100
Serial number: [redacted]
Firmware date: 2116-08-31 11:53
Bus encryption flags: 1F
Highest AACS version: 76
When using SDF tool Flasher I get the following error message : "The drive you have selected does not have the correct drive platform (MT1959) and cannot be flashed."
The drive seems to read UHD discs okay, the show up in Windows Explorer. Even copied an encrypted disc to a hard drive without issue.
Any advice on what I can do to make this drive work?
Ultimate UHD Drives Flashing Guide Updated 2025
Mind sending a link to those?Billycar11 wrote: ↑Sun Jul 21, 2024 4:11 amUse the force flash commandshipsofjw wrote: ↑Sun Jul 21, 2024 3:24 amMakeMKV is not showing any LibreDrive information for this drive. I am on the latest version of MakeMKV.MartyMcNuts wrote: ↑Sun Jul 21, 2024 12:20 am
Here's what Powershell is giving me:Billycar11 wrote: ↑Sun Jul 21, 2024 4:11 amUse the force flash commandshipsofjw wrote: ↑Sun Jul 21, 2024 3:24 amMakeMKV is not showing any LibreDrive information for this drive. I am on the latest version of MakeMKV.MartyMcNuts wrote: ↑Sun Jul 21, 2024 12:20 am
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d G: rawflash -i C:\Users\k\Downloads\DE_LG_BU40N_1.00.bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
Also tried it with "enc"
While waiting for my previous posts to be approved, I solved the issue by adding the -t mtk991 command. Already made my first rip. Thanks for the help!
PS C:\Program Files (x86)\MakeMKV> .\makemkvcon64.exe f --all-yes -d G: rawflash -t mtk19xx -i C:\Users\k\Downloads\DE_LG_BU40N_1.03_MK.bin
Reading input file C:\Users\k\Downloads\DE_LG_BU40N_1.03_MK.bin
Current Drive ID: HL-DT-ST__BD-RE_BU40N_U100_211608311153_KFKGAJA1621
100% Operation finished
Done successfully
Done successfully
New here but eager to learn. I get the following error code when trying to flash the LG drive: Ox82052603
I'm using an LG BD-RE WH14NS40, firmware 1.05, drive platform MT1959, the SVC code on the drive is NS50. the drive enclosure is an OWC Mercury Pro professional USB 3.0 model OWCMR3UKIT
I used the SDFtool flasher v1.3.5 and firmware pack DE_LG_WH14NS40-N S50_1.02.bin. if it matters I'm using a newer laptop with a core I9 processor running windows 11. Thanks
bjl1959 wrote: ↑Wed Jul 24, 2024 3:15 amNew here but eager to learn. I get the following error code when trying to flash the LG drive: Ox82052603
Guide says:
WH14NS40 on any Firmware directly to > WH16NS60 1.02MK... NOT 'DE'
Thanks. I'll download the firmware files again. FYI I downloaded the all you need firmware file and the DE files were all I seen after unzipping. I'll check it again using the link you provided. Thanks again.
Just make sure it is WH16NS60 1.02-MK. Doesn't matter if also DE.
Good day everyone,
Have a Archgon MD-8107S-U3-UHD drive with the drive info below. Do I need to flash the firmware for basic functionality? Any guidance greatly appreciated.
Thanks in advance.Product: BD-RE BU40N
Revision: 1.00
Firmware: 2116-12-20 15:28
Drive Platform: MT1959
Firmware version: 1.0
Hi everyone,
im pretty new to this stuff an I want to backup my UHD collection.
I'm in located in Germany, so I bought the Verbatim 43888 as it is available
in local stores.
When I trie to rip the "The Thing" UHD I get the following message
"AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
AACS Ausgabedatei als C:\Users\info/.MakeMKV/MKB20_v76_The_Thing_920D.tgz gesichert
Das Öffnen der Disk schlug fehl"
It's in German, sorry.
Here is the Information from MKVMaker
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer: [redacted]
Firmware-Datum: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Thanks in advance
in local stores.
Produzent: PIONEER
Revision: 1.14
Thanks in advance
downloaded the files again and used the WH16 version of the firmware. everything is now working. Thanks much for your help.MartyMcNuts wrote: ↑Thu Jul 25, 2024 6:43 amJust make sure it is WH16NS60 1.02-MK. Doesn't matter if also DE.
I recently wrote a post about trying to rip a UHD and getting a dump file: https://forum.makemkv.com/forum/viewtopic.php?p=156849#p156849Zadok666 wrote: ↑Tue Jul 30, 2024 2:28 pmHi everyone,
in local stores.
Produzent: PIONEER
Revision: 1.14
Thanks in advance
The UHD FAQ is also a good resource.
Good evening, I have a uj240as but it has version 1.02. I bought it recently since the internal drives are expensive and my lg has been in use for a long time.
but all the places I found have broken links
The UJ240AS is never going to do UHD, as it was discontinued years before UHD was a thing. You are limited to DVD and (regular) BD reading, no matter what software version you have.
Backing up disc into folder "E:/Video/backup/The shaolin temple"
Downloading latest HK to C:\Users\123/.MakeMKV ...
Saved AACS dump file as C:\Users\123/.MakeMKV/MKB20_v77_The_shaolin_temple_0C5E.tgz
Backup failed
Backup failed
