Error 'OS error - Access is denied'
clarkss12
#1 Post by clarkss12 » Wed Jul 24, 2024 7:46 pm
I keep getting this same message for every rip I perform. What am I doing wrong? Thanks
Error 'OS error - Access is denied' occurred while creating 'C:/Program Files (x86)/MakeMKV/MKB_v7_save.tgz'
Re: Error 'OS error - Access is denied'
#2 Post by d00zah » Wed Jul 24, 2024 8:11 pm
clarkss12 wrote: Wed Jul 24, 2024 7:46 pm I keep getting this same message for every rip I perform. What am I doing wrong? Thanks
You changed your MakeMKV data directory location (Preferences > General tab) to someplace you don't have permission to write to. Default is %UserProfile%\.MakeMKV
Best to use the default because:
- you don't need to change access permissions
- you don't wipe out any customizations when you update to a new version of MakeMKV
clarkss12
#3 Post by clarkss12 » Wed Jul 24, 2024 9:21 pm
d00zah wrote: Wed Jul 24, 2024 8:11 pm
Ok, thank you. I will try to set it the default location.
clarkss12
#4 Post by clarkss12 » Wed Jul 24, 2024 9:36 pm
I uninstalled the app but when I download it and install it, it still wants to install to my "C:\Program Files (x86)" location,
How do I get it to install to the default location?? Thanks.
#5 Post by d00zah » Wed Jul 24, 2024 9:44 pm
clarkss12 wrote: Wed Jul 24, 2024 9:36 pm I uninstalled the app but when I download it and install it, it still wants to install to my "C:\Program Files (x86)" location,
The installation location is correct.
Preferences > General tab > MakeMKV data directory
By default (windows) this is defined as C:\Users\yourusername/.MakeMKV
You changed this location (or so it appears) to the installation directory, which you don't have write access to, All you need to do is NOT change that default location after installation.
clarkss12
#6 Post by clarkss12 » Wed Jul 24, 2024 9:56 pm
With each of your suggestions, it is working now without the error message. Thanks.
#7 Post by d00zah » Wed Jul 24, 2024 10:00 pm
clarkss12 wrote: Wed Jul 24, 2024 9:56 pm With each of your suggestions, it is working now without the error message. Thanks.
Glad to help. Welcome & enjoy..
