Sure! PM sent.Jucabala2 wrote: ↑Fri Jul 19, 2024 8:39 pmHi Coopervid! Can you help me witj this? I just purchased my BDR-212DBK.
Thank you!
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.00 Serial number: [redacted] Firmware date: 2019-01-10 Bus encryption flags: 13 Highest AACS version: 14 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.00/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Pioneer BDR-212DBK vs BDR-212V
Re: Pioneer BDR-212DBK vs BDR-212V
Thanks everyone for the help! I returned all other drives and got a BDR-212DBK instead which has LibreDrive support out of the box (tested it successfully) so now I'm a happy camper, cheers!
I just purchased a BDR-212V.
@Coopervid would you mind helping me out with the firmware update, too?
Here are the drive details:
OS device name: F:
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXXX
Firmware date: 2022-05-31
Highest AACS version: 81
Firmware version: ID06
No disc insertedRe: Pioneer BDR-212DBK vs BDR-212V
That was easy! My 212V can now read UHD.
@Coopervid thanks so much!
jtsapps217
Hi @Coopervid,
I also have a BDR-212V and I am looking for the instructions on how to flash. Would you send those to me please? I can't PM yet, but maybe you can PM me.
Thank you.
Thank you.
PM sent.jtsapps217 wrote: ↑Thu Jul 25, 2024 12:59 pmHi @Coopervid,
Thank you.
Your PM will expire Monday!Jucabala2 wrote: ↑Fri Jul 19, 2024 8:39 pmHi Coopervid! Can you help me witj this? I just purchased my BDR-212DBK.
Thank you!
@Coopervid, just picked up two BDR-212V's off of amazon, would you be able to PM me for the flasher for these? Thank you very much in advance!
I just emailed you sir! Thank you very much.
Hi, i have a Rev 1.00 Pioneer BRD-212V. could i get some help with the flashing?
Thanks.
OS device name: F:
Revision: 1.00
Serial number: xxxxxxxxxxxx
Firmware date: 2020-08-07
Highest AACS version: 68
Firmware version: 1.00/ID06
Sure email me see belowspanishh_ wrote: ↑Tue Sep 03, 2024 9:11 pmHi, i have a Rev 1.00 Pioneer BRD-212V. could i get some help with the flashing?
Thanks.Code: Select all
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.00 Serial number: xxxxxxxxxxxx Firmware date: 2020-08-07 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.00/ID06 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
RicardoDeLoon
Hey @Coopervid
Could you please send me a PM too
OS device name: E:
Revision: 1.02
Serial number: [REDACTED]
Firmware date: 2022-03-16
Firmware name: PIONEER BDR-2121
Firmware version: 1.02/1D61
OS device name: E:
Revision: 1.02
