Pioneer BDR-UD03 UHD possibility
Verbatim43890
Re: Pioneer BDR-UD03 UHD possibility
Lookingfor UHD patch
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
OS device name: E:
Revision: 1.14
Read your PM.Verbatim43890 wrote: Mon Jul 22, 2024 11:09 pm Lookingfor UHD patch
OS device name: E:
Revision: 1.14
PM sent.rx782isdaddy wrote: Mon Jul 22, 2024 10:51 pm Hi,
Could I please have a copy of the firmware for my UD03 drive?
Much appreciated!
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: DDDL525959WL Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
Verbatim43890
Thank you
The-JK
Hi, Looking for UHD firmware for below drive, Thank you very much in advance!
OS device name: /dev/sr0
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 63
Drive platform: Pioneer RS8510
Firmware version: ID23
Revision: 1.00
That drive was built almost two years before UHD became available. Not likely it will ever do UHD.Firmware date: 2014-04-01
You would be surprised how long Pioneer hardware was UHD capable and only newer firmware is needed.Woodstock wrote: Wed Jul 24, 2024 12:44 pmThat drive was built almost two years before UHD became available. Not likely it will ever do UHD.Firmware date: 2014-04-01
Read your PM.The-JK wrote: Wed Jul 24, 2024 3:30 am Hi, Looking for UHD firmware for below drive, Thank you very much in advance!
Revision: 1.00
Yes.Dr. Azathoth wrote: Mon Jul 22, 2024 9:53 pmThank you!Coopervid wrote: Mon Jul 22, 2024 9:32 pm All links will expire one week after being posted and no new links will be provided.
Out of curiosity, is there a reason why this firmware isn't public like the one in the "all you need firmware pack"?
All PMs will expire after one week if not read. Then no more PMs for these folks.
The-JK
Thank you so much!!Coopervid wrote: Wed Jul 24, 2024 4:57 pmRead your PM.The-JK wrote: Wed Jul 24, 2024 3:30 am Hi, Looking for UHD firmware for below drive, Thank you very much in advance!
Revision: 1.00
For any users interested confirming this works on drives rebadged as Silverstone TOB04
Hoshimiya
Greetings, I also currently has a BDR-UD03 with the following specs:
I see that it might be possible to patch the firmware to support UHD?
Any help will be much appreciated, and thanks in advance
OS device name: M:
Revision: 1.14
Serial number: --------------
Highest AACS version: 76
PM sent.Hoshimiya wrote: Thu Jul 25, 2024 2:07 am Greetings, I also currently has a BDR-UD03 with the following specs:I see that it might be possible to patch the firmware to support UHD?Code: Select all
Drive Information OS device name: M: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: -------------- Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Hoshimiya
Very much appreciated thanks! My drive is now recognized as UD04 and can read UHD great with your provided filesCoopervid wrote: Thu Jul 25, 2024 9:14 amPM sent.Hoshimiya wrote: Thu Jul 25, 2024 2:07 am Greetings, I also currently has a BDR-UD03 with the following specs:I see that it might be possible to patch the firmware to support UHD?Code: Select all
bdrud03
My drive is as follows:
OS device name: E:
Revision: 1.14
Highest AACS version: 12
Great thanks in advance!
OS device name: E:
Revision: 1.14
