Not sure what you mean by a comparison??Joannebok wrote: Sun Jul 21, 2024 12:30 am Hi Marty, can you point me to a comparison for the drives you have in stock? I am thinking of getting one of your internal pioneer drives. I assume internal drives are more reliable?
UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
I mean to ask what is the difference between each of the drives?
The higher the price, the better quality components and overall build quality.Joannebok wrote: Sun Jul 21, 2024 12:36 pm I mean to ask what is the difference between each of the drives?
If you want to know about speed, they all read UHD discs at 4x max.
I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
No problem. Unfortunately there are currently no compatible external Pioneer drives available as they all come with un-downgradable firmware. There is the Verbatim 43888 which contains a Pioneer BDR-UD04 drive inside but that's it.Joannebok wrote: Tue Jul 23, 2024 3:34 am I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
Stock levels updated in first post.
