NEW Single Drive Flasher - available worldwide!!
Re: UHD Enabled Drives (Australia, NZ & Singapore among others!) & DIY "Single Drive Flasher UI" available worldwide!!
Joannebok wrote: Sun Jul 21, 2024 12:30 am Hi Marty, can you point me to a comparison for the drives you have in stock? I am thinking of getting one of your internal pioneer drives. I assume internal drives are more reliable?
Not sure what you mean by a comparison??
Joannebok
Post by Joannebok »
I mean to ask what is the difference between each of the drives?
Joannebok wrote: Sun Jul 21, 2024 12:36 pm I mean to ask what is the difference between each of the drives?
The higher the price, the better quality components and overall build quality.
If you want to know about speed, they all read UHD discs at 4x max.
Joannebok
Post by Joannebok »
I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
Joannebok wrote: Tue Jul 23, 2024 3:34 am I read elsewhere that external drives have less points of failure than internal drives. I will do my own research, thanks for your advice.
No problem. Unfortunately there are currently no compatible external Pioneer drives available as they all come with un-downgradable firmware. There is the Verbatim 43888 which contains a Pioneer BDR-UD04 drive inside but that's it.
Stock levels updated in first post.
