yeah for some people, cropping doesnt work and i don't know why.
It works now, I uninstalled and reinstalled both LAV filters and madvr. The problem was probably due to an outdated version of madvr.RESET_9999 wrote: ↑Thu Jul 18, 2024 8:08 pmyeah for some people, cropping doesnt work and i don't know why.
Thank you!sw5163 wrote: ↑Thu Jul 18, 2024 7:01 amCM v4.0 provides creators more control over tone mapping, thus it's more accurate when applied properly.
https://professionalsupport.dolby.com/s ... v-4-0-FAQs
https://professionalsupport.dolby.com/s ... tween-them
I'll get to this eventually - HVAC broke with part backordered so been out of my house for a couple weeksFonduemangVI wrote: ↑Sun Jul 07, 2024 11:51 pmI just had a chance to check Mando and I can't see any sync issue. Can you provide a particular timestamp?staknhalo wrote: ↑Tue Jun 25, 2024 7:37 pmwhatever problems watching at the computer/windows platform aside - is that the best windows store dv player then outside of any official dv pcs player etc?
Framestor Mando S02E08 Hybrid UHD out of sync too - prob all the (d+ or iT/D?) stuffRESET_9999 wrote: ↑Tue Jun 18, 2024 5:04 pmand it's only because I know him personally and I know that he always does all the necessary checks.
Some older framestor releases are wrong and I just checked the Captain America hybrid is still available on BHD even though it's a VERY different grade and the RPU is not even in sync with the BL.
Same for their Black Widow release and others.
You can pm the list of hybrids you're not sure and I can have a look if i can find them.
What is DEE.exe and how I can get it ?
Awesome thread, been following since quietvoid shared his method. Recently grabbed Ugoos AM6B Plus and have been updating DV files in my library. Afew questions would really save me some time:
-I just started using Reset_9999's tools afew days ago, all my DV profile 8 files have been created with quietvoids old bat files, is there
any reasons to redo these profile 8 again with Reset_9999's tools since they are maintained/updated?
-I've been using 4-2 workflow with the new tools to create fel and it works really well but I cant workout how to choose which streams i want to encode instead of the whole .m2ts file - choose which audio, no subs etc.
-Is there a updated database somewhere that listed what UHD are FEL? so I know which films I have to update.
No, my ''tools'' are just scripts that use the same quietvoid's dovi_tool.exe-I just started using Reset_9999's tools afew days ago, all my DV profile 8 files have been created with quietvoids old bat files, is there
Or maybe you meant yusesope's old bat file (original method)? If your file works, I see no reason to remux them again with the newer dovi_tool.exe
dovi_scripts has a workflow to create ST-DL but it's not very useful/efficient because it has to mux to a hevc file with dovi_tool and then mux to MKV. It would be best/faster if you used MakeMKV(free in beta) or mkvtoolnix instead, because it can mux a BD to ST-DL straight to MKV and you can select any audio/subs.-I've been using 4-2 workflow with the new tools to create fel and it works really well but I cant workout how to choose which streams i want to encode instead of the whole .m2ts file - choose which audio, no subs etc.
viewtopic.php?t=1053
idk but dovi_scripts Workflow 2-2 can quickly find if any input is FEL or MEL.Is there a updated database somewhere that listed what UHD are FEL? so I know which films I have to update.
Thanks for the reply and all the answers.
I did not realize I could just drop the .m2ts file in toolnix and it would export STDL file, working great!
@RESET_9999 How do you get the dolby vision streaming version of Goodfellas? Can't find it anywhere.
i dont remember
In your "grade master check" section on your Google Sheets, you listed encoders to avoid doing DV hybrids. Any opinions on DVSUX, TEPES, LEGiON, DVT, FraMeSToR (not MainFrame), HuN-TRiNiTY, and Flights? I know that's a lot, I had no idea this was a full fledged community.
Reset please advice torrent trackers with good seeding
my favorite tracker is BHD.
How can i get there only for donation or how ?
