Olympus Had Fallen
Jstokes57
Olympus Had Fallen
Post by Jstokes57 »
Apparently they have advance encryption again, all I can see is the previews for other movies. Anyone else have this issue? New movie from Amazon, plays fine but unable to rip it.
Re: Olympus Had Fallen
And MakeMKV says what about it? Does it say that it created a .TGZ file to have a key generated? Did you send that .TGZ file to svq@makemkv.com so that that key can be generated?
Or was there some other error?
Jstokes57
Post by Jstokes57 »
Below is the error log file results
Debug log started at Thu Jul 25 06:34:09 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\jstok/MakeMKV_log.txt
No SDF v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLGK5BF2235
DEBUG: Code 3 at (Fjq;j%;wku%(|]PM?.".JoL:29395310
SDF id v098: HL-DT-ST_BD-RE__WH16NS40_1.04_211901041348_KLGK5BF2235
Application exited at Thu Jul 25 06:35:15 2024
Jstokes57 wrote: Thu Jul 25, 2024 6:43 am Below is the error log file results
This log doesn't show MakeMKV trying to do anything. It shows the application starting up, doing nothing, then shutting down about 1 second later.
