power outage when flashing
Re: power outage when flashing
#16 Post by Billycar11 » Thu Jul 18, 2024 9:38 am
truemaster wrote: Thu Jul 18, 2024 9:36 am yes thats exacly the dosflash im using. i flash to wh16ns60 1.00 as instructed with makemkvcon64.exe. since the drive is in boot mode and sdfgui refuse to flash it. but dosflash still cant intro the device
i have seen drives in boot mode before you can flash them with the offical LG tool then downgrade to wh16ns60 1.02mk
then full flash down to 1.00 wh16ns60
then try again in dos
#17 Post by Billycar11 » Thu Jul 18, 2024 9:40 am
also your sure your using tht dos flash the one in the video looks like normal but its modified to support these chips.
make sure your using it
its linked in description
truemaster
#18 Post by truemaster » Thu Jul 18, 2024 9:44 am
yes i download it and has the same names dates and i even try completly with one on the video. also its strange that the drive is in boot mode but the drive report it self as bh16ns60? i never try to flash with such firmware
truemaster
#19 Post by truemaster » Thu Jul 18, 2024 10:09 am
and cant find an official flasher to unstuck it from boot mode
#20 Post by Billycar11 » Thu Jul 18, 2024 10:16 am
truemaster wrote: Thu Jul 18, 2024 10:09 am and cant find an official flasher to unstuck it from boot mode
what one are you using?
you can try the unlocked lg flasher here: https://drive.google.com/file/d/102V7DU ... sp=sharing
and flash 1.00 de wh16ns60
truemaster
#21 Post by truemaster » Thu Jul 18, 2024 10:24 am
oh i tryed that one as well i select the wh16ns60 firmware and when i hit flash it throws
checksum is mismatched drive will go to boot mode plese retry again
#22 Post by Billycar11 » Thu Jul 18, 2024 10:28 am
truemaster wrote: Thu Jul 18, 2024 10:24 am oh i tryed that one as well i select the wh16ns60 firmware and when i hit flash it throws
what fw is your drive on now?
are flashes in makemkv working?
post the drive info again
truemaster
#23 Post by truemaster » Thu Jul 18, 2024 10:34 am
OS device name: G:
Product: BD-RE BH16NS60
Revision: BOOT
strange isnt but its the same drive as yesterday
the only flasher that works is makemkvcon64.exe but the drive status isnt change
#24 Post by Billycar11 » Thu Jul 18, 2024 10:38 am
truemaster wrote: Thu Jul 18, 2024 10:34 am Drive Information
OS device name: G:
Revision: BOOT
i have only seen drives get stuck in boot mode if your using chipset or usb adapter that can pass through flashing commands.
how is the drive hooked up?
you tried this one?
https://hitachi-lg.com/en/support/firmware_download/
truemaster
#25 Post by truemaster » Thu Jul 18, 2024 10:44 am
the drive is hooped up with usb but i also try it with internal sata ports with same results.
#26 Post by Billycar11 » Thu Jul 18, 2024 10:46 am
truemaster wrote: Thu Jul 18, 2024 10:44 am the drive is hooped up with usb but i also try it with internal sata ports with same results.
dosflash is sata only your wasting you time and mine like that what sata adapter?
plz go plug it in to sata
also your sure you bios is in ide mode?
lets see screen shot of that
whats your motherboard? or cpu
truemaster
#27 Post by truemaster » Thu Jul 18, 2024 10:55 am
wait when trying with dosflash i hook with internal sata. i know usb isnt ok with dosflash.
im using a vt6421 pci to sata for dosflash on old computer that i used to flash xbox 360 drives that computer is only ide so the dosflash part its fine. my new computer isnt compatible with dosflash even on ide mode
#28 Post by Billycar11 » Thu Jul 18, 2024 11:13 am
truemaster wrote: Thu Jul 18, 2024 10:55 am wait when trying with dosflash i hook with internal sata. i know usb isnt ok with dosflash.
i was talking about the usb one have you tried running those flashers when on direct sata not the usb one.
you should be able to get out of boot mode
truemaster
#29 Post by truemaster » Thu Jul 18, 2024 11:18 am
i had tryed with internal sata on my modern computer too.
here some screenshots from my retro computer that doshflash is compatible with
ahh cant upload screeshots quaota exxeds
#30 Post by Billycar11 » Thu Jul 18, 2024 11:26 am
truemaster wrote: Thu Jul 18, 2024 11:18 am i had tryed with internal sata on my modern computer too.
imgur
