Pioneer BDR-UD03 UHD possibility
smarthead
Re: Pioneer BDR-UD03 UHD possibility
Could you rovide the UHD patch for me as well:
Laufwerksinformation
OS-Gerätename: F:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.10
Serienummer: SLDLxxxxxxxx
Firmware-Datum: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10
Thanks & regards,
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.10
Thanks & regards,
Of course. Read your PM.smarthead wrote: Tue Jul 16, 2024 4:49 pm Could you rovide the UHD patch for me as well:
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.10
Thanks & regards,
smarthead
Marvellous, works like a charm, thanks !
mandrix
I have a verbatim/Pioneer clone UD03.
Could you share the firmware to allow UHD ripping?
Thanks.
Thanks.
PM sent.mandrix wrote: Wed Jul 17, 2024 10:13 pm Hi,
Thanks.
mandrix
Works like a charm. Thank you so much.
NewBostonConst
Would like to update firmware....thanks for your time....
OS device name: E:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Firmware version: 1.14
OS device name: E:
Revision: 1.14
maxxie
Sweet, worked! Much appreciated!
Dr. Azathoth
Could I have a copy of the firmware for my UD03 drive?
OS device name: E:
Revision: 1.14
Highest AACS version: 72
Unrestricted read speed: Yes-
Pm sentNewBostonConst wrote: Fri Jul 19, 2024 5:16 pm Would like to update firmware....thanks for your time....
OS device name: E:
Revision: 1.14
PM sentDr. Azathoth wrote: Mon Jul 22, 2024 7:52 pm Hello,
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: [redacted] Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 72 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
All links will expire one week after being posted and no new links will be provided.
Dr. Azathoth
Thank you!Coopervid wrote: Mon Jul 22, 2024 9:32 pm All links will expire one week after being posted and no new links will be provided.
Out of curiosity, is there a reason why this firmware isn't public like the one in the "all you need firmware pack"?
And no mercy. This forum and especially new members are just horrible. I just call them a bunch of idiots. Forgive me but if someone asks for help and then never reads his PM I have no other term.
rx782isdaddy
Could I please have a copy of the firmware for my UD03 drive?
Much appreciated!
Much appreciated!
OS device name: E:
Revision: 1.14
Serial number: DDDL525959WL
