power outage when flashing
and now my bh16ns55 cant read any media reflashing isnt working and i have no backup files. how can i recover? my bet cal data is corrupted in the flash
Re: power outage when flashing
What's the build date on your drive?
What your makemkv drive info section say?
march 2023
i reflash with some wh16ns60 and bh16ns55 but nothing cant read any media
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: 4 xf i +
Firmware date: 2120-05-08 10:10
Firmware version: 1.03
OS device name: E:
Revision: 1.03
Try using the official LG updatertruemaster wrote: ↑Wed Jul 17, 2024 8:10 pmmarch 2023
OS device name: E:
Revision: 1.03
The WH16NS60 one
Does sn really show up like that?
i have try to flash with official lg 1.03 wh16ns60 firmware and nothing. sn is looks strange to me too i think this drive needs full fw flash with dosflash. i have a comatible sata but this drive wont enter vendor mode (status 51)
Flash back to your normal drive then use that LG updater and see if it works
i did no stil no reading and the strange serial remains
i see well that really should not happen but i do see sn is messed up and thats with cal data.
i have alot of old cal data i can share with you for lg and asus drives so if you get dosflash working i can send it to you to flash
dosflash cant ventor intro this drive. i can flash othe drives fine though. make mkv makemkvcon64.exe can flash it though but does write the eeprom area of the drive too? if not do you know how to unlock this drive for dosflash
Try flashing WH16NS60 1.00. This should hopefully then allow the use of Dosflash.truemaster wrote: ↑Thu Jul 18, 2024 6:19 amdosflash cant ventor intro this drive. i can flash othe drives fine though. make mkv makemkvcon64.exe can flash it though but does write the eeprom area of the drive too? if not do you know how to unlock this drive for dosflash
no dosflash still cant intro the device. im using the bh16ns40 patched dosflash. does full msdos dosflash be any different? also the drive is stuck now in boot mode
Be sure your using 32 bit windows in ide modetruemaster wrote: ↑Thu Jul 18, 2024 7:44 amno dosflash still cant intro the device. im using the bh16ns40 patched dosflash. does full msdos dosflash be any different? also the drive is stuck now in boot mode
Also makesure your using the dosflash provided in my video.
And as Marty said you should be on WH16NS60 1.00 with full flash to make sure bootloader is written as that what dosflash talks to
yes im using 32 bit windows. ive use dosflash multiple time so i know my pc is compatible with it. but where can i find you version of dosflash? maybe yours can intro the device and can write read to it
https://www.youtube.com/watch?v=eXgybNfHhcgtruemaster wrote: ↑Thu Jul 18, 2024 9:20 amyes im using 32 bit windows. ive use dosflash multiple time so i know my pc is compatible with it. but where can i find you version of dosflash? maybe yours can intro the device and can write read to it
yes thats exacly the dosflash im using. i flash to wh16ns60 1.00 as instructed with makemkvcon64.exe. since the drive is in boot mode and sdfgui refuse to flash it. but dosflash still cant intro the device
