Here's To hoping someone can give a SIMPLE explination on where the errors are.
OldRecordPlayer
#1 Post by OldRecordPlayer » Wed Jul 17, 2024 6:15 pm
Of course I am just replacing the disk, but like G.I. Joe said, "Knowing Is half the battle."
P.S. please also keep in mind I already watched the movie on a Samsung Blu-ray player attached to my T.V.
MakeMKV v1.17.6 win(x64-release) started
Using LibreDrive mode (v01.0 id=95C4500CE7CA)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1X-U E111 RFDL019598WL' at offset '5560801280'
Can't locate a cell for VTS 1 TTN 1 PGCN 2 PGN 1
Can't locate a cell for VTS 1 TTN 1 PGCN 3 PGN 1
Can't locate a cell for VTS 1 TTN 1 PGCN 4 PGN 1
Title #1 has length of 14 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #2 has length of 1 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Can't locate a cell for VTS 8 TTN 1 PGCN 4 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 7 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 8 PGN 1
Title #8/1 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/2 has length of 16 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/3 has length of 47 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/4 has length of 35 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/5 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/6 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/7 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/8 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/9 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #8/10 has length of 5 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Cells 35-35 were removed from title end
Title #11 was added (34 cell(s), 2:07:59)
Title #13 has length of 10 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #15 has length of 102 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Title #22 has length of 32 seconds which is less than minimum title length of 150 seconds and was therefore skipped
Saving 1 titles into directory D:/Video Rips
AV sync issue in stream 2 at 1:09:14.048 with duration of 35.266ms : audio gap - 3.306 missing frame(s)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '227794944'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '227794944'
Failed to save title 0 to file D:/Video Rips/007 - 1999 - The World Is Not Enough_t00.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Re: Here's To hoping someone can give a SIMPLE explination on where the errors are.
#2 Post by dcoke22 » Wed Jul 17, 2024 7:52 pm
I'm not sure I understand what you're asking.
This message:
indicates that your drive was unable to correctly read a spot on that disc. The standard advice would be to gently clean the disc and try again, although I assume you've tried that already.
Most DVD and blu-ray players are programmed to blow past any read errors and hope you don't notice the resulting video or audio errors.
OldRecordPlayer
#3 Post by OldRecordPlayer » Wed Jul 17, 2024 7:57 pm
Thanks...
I do have a JFJ Pro resurfacing machine and you are correct, no effect after three one-minute cycles. So you gave me confirmation on two things actually.
Thanks!!!
