RIO Fails backup
Re: RIO Fails backup
Great work! Thanks a million, love this software.
Rio Failed Backup.
It seems get the correct SVQ file but it still fails.
These are messages I'm getting:
DAFD=PAAAADAAAAEABDQEEAQEBAQ==
DCE=3VudAD62+ywICkoFB/DwGnMplaEEgpI7aSMzY9/qgCzNTMYVwP6bfO3OsvIXp7rPHhY5V+Jq9D6vk1yaOUaC3cNaZzaUzumziJQxDImmVIuUYS/sPiwKqTvJLSzDgdCLEGcVMPHKj6ljZQY03qf9PPathz9RJeUhkQ==
003338:0000 Downloading latest SVQ(s) to /Volumes/Movies_4 ...
003317:0000 Loaded 23 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003322:0000 Processing BD+ code using disc-specific SVQ from 00000018.svq
003332:0000 Saved BD+ dump file as dump_Rio_DC95A8328085F4D6.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
001003:0020 DEBUG: Code 2 at f^0X?}ZDxr7|FiD$jfEvcs:29393677
001003:0020 DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:121268949
001003:0020 DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:121266994
001003:0020 DEBUG: Code 0 at Ld;''""b461[$i1U-w)%:213142542
005069:0080 Backup failed
005080:0204 Backup failed.
I'm not really sure how the SVQ thing works, but I was able to get this to work for me by first deselecting the Decrypt option in the backup. Do a full disk backup, then move the DCOPY and other extra folders out of the MKV directory. Reopen the MKV directory with MakeMKV and choose Backup again with the Decrypt option selected. Then I was able to use handbrake on the decrypted MKV directory. Took a bit of experimenting, but I was able to make it work with out the SVQ thing, whatever that is?
- Contact:
otter123 wrote:Rio Failed Backup.
For whatever reasons MakeMKV failed to save files in a folder that you've selected. Please check the folder name, disc size and permissions.
I have the same problem as otter123. Changing drives, folders, and file names have no effect. Ryanide may have hit the nail on the head with the DCOPY folder, it always fails at "/DCOPY/Rio_EN20_NoSubs_Theatrical_PD_NAS_4502818_1155205.dc". Using v1.6.14 64 bit and it is loading the 00000018.sqv file.
Attached the files described in the faq.
- Rio Blu-Ray.zip
- (144.84 KiB) Downloaded 807 times
- Contact:
Interesting. What happens if you try to copy this file manually?
I am having problems with Rio too. I am using version 1.6.15. I tried getting the file dsall.svq and put in in the /users/me/.MakeMKV folder and it still fails during backup. The only thing about svq I see during this is:
Processing BD+ code using generic SVQ from builtin/00003.svq
What am I doing wrong here?
Thanks.
Thanks.
setarip_old
@kcsims
Try it again and submit a log...
If, in fact , that is the ONLY message you see regarding BD+, then your setup has PROPERLY processed the BD+ - and your failure problem has nothing to do with BD+.The only thing about svq I see during this is:
Backing up disc into folder "Y:\temp"
Loaded 1 SVQ file(s)
Saved BD+ dump file as C:\Users\Kevin/.MakeMKV/dump_Rio_77C11C94450BBAA3.tgz
DEBUG: Code 3 at =//6sh'XaNSCO|.BY6O+o:121261750
DEBUG: Code 0 at 6An,V|ea@|+X~ j.>H7H:121268949
DEBUG: Code 0 at 6An,V|ea@|+X~ j.>H7H:121266994
DEBUG: Code 0 at 6An,V|ea@|+X~ j.>H7H:213142542
Backup failed
Backup failed
- MakeMKV_log.txt
- Log File
- (1.61 KiB) Downloaded 835 times
Rio backed up no problem for me. Put in disc. Backed up main feature. Converted in handbrake. Plays fine.
I just uninstalled and reinstalled....same thing.
Did you flag in the config, I think it's named something like "Check on internet for update" or "Log on internet for SVQ update" available with 1.6.14 ?
I wasn't able to decrypt it with this unflagged.
I hope this could help.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
Yup, had it checked, still same thing. I ended up having to just copy the entire disc to my hard drive, delete the BD+ folder, repack it to an ISO, mount the ISO with daemon tools, and then use makemkv to make a .m2ts file for me.....
- Contact:
And it worked???kcsims wrote:Yup, had it checked, still same thing. I ended up having to just copy the entire disc to my hard drive, delete the BD+ folder, repack it to an ISO, mount the ISO with daemon tools, and then use makemkv to make a .m2ts file for me.....
You sound surprised. Yeah, worked fine for Rio and the new X-men. Only problem I have with Xmen and a few others is the forced subtitles don't work for m2ts files. Know of any fix?mike admin wrote:And it worked???kcsims wrote:Yup, had it checked, still same thing. I ended up having to just copy the entire disc to my hard drive, delete the BD+ folder, repack it to an ISO, mount the ISO with daemon tools, and then use makemkv to make a .m2ts file for me.....
