Her (2013) -USA
PandaMan86
Her (2013) -USA
Post by PandaMan86 » Sun Jul 14, 2024 3:44 pm
Hi all,
I'm trying to rip the movie Her (2013). Getting the following errors. Anyone able to help? Full log below.
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '15217262592'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00042.m2ts' at offset '15217262592'
Drive information
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-07-21
Highest AACS version: 76
Drive platform: RS8F01
Firmware version: 1.01/ID72
Using LibreDrive mode (v01.0 id=2AE09FD4F501)
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
File 00100.mpls was added as title #1
Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00120.mpls was added as title #2
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.m2ts was added as title #3
Title #00011.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00032.m2ts was added as title #4
File 00033.m2ts was added as title #5
Title #00034.m2ts has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00059.m2ts was added as title #6
Title #00060.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory J:/To Be Sorted - Jumbo
Failed to save title 1 to file J:/To Be Sorted - Jumbo/Her (2013).mkv
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Re: Her (2013) -USA
Post by dcoke22 » Sun Jul 14, 2024 11:54 pm
Those errors typically mean the disc is either dirty or damaged at that spot. Gently clean the disc then try ripping again.
