Marty or anyone else please help...MakeMKV not working with LG WH16NS40?
isamu
I'm trying to get VLC to play my UHD Bluray. In this case it's The Big Boss with Bruce Lee. MKV appears to recognize the disc fine because delivers all the information about in the "Info" section. But upon trying to play the movie in VLC, VLC just hangs, with the little vertical bar sliding back and forth.
My drive is an LG WH16NS40, currently flashed with fw WH16NS40 1.02. Based on recommendations from this forum, I tried flashing it with fw LG WH16NS60 1.02 and the results were the same. Can you tell which is the current correct fw for this drive specifically to work with MKV and VLC to only watch movies?
Oh and one more thing...is AnyDVD HD required to work with decrypting and watching UHD movies with the MKV/VLC combo? Or is it simply not needed?
Re: Marty or anyone else please help...MakeMKV not working with LG WH16NS40?
Is makemkv integration enabled?
Does makemkv open or rip a disc on its own?
In VLC be sure to use this procedure
Select Open disc
Select Blu-ray select the drive or make sure it right
Then play
Select Open disc
Then play
isamu
Thanks for your reply Billy. OK so first of all...Billycar11 wrote: Sun Jul 14, 2024 12:57 am Is makemkv integration enabled?
Select Open disc
Then play
1)Is makemkv integration enabled?
YES
______________________________________________
2)Does makemkv open or rip a disc on its own?
No. Upon selecting the File>Backup>Select output directory option, I get a failed to backup error.
3)In VLC be sure to use this procedure
Select Open disc
Then play
Yup tried that and VLC gives me an error saying Bluray disc is corrupted.
Was able to watch the movie(for the most part) using Leawo Bluray player using the default WH16NS40 firmware, but that player sucks and was giving me intermittent black screen and freeezing problems.
I've tried all the different kinds of firmware 1.02MK, 1.00, 1.03 and MKV doesn't want to play nice with this disc. For what it's worth, it's a Layer 3 UHD disc. I've heard these LG drives suck at reading layer 3 discs so maybe that's the culprit?
Please let me know what else I should try this is driving me up the wall! I'll try Firmware DE_LG_WH16NS60-1.02MK.bin again and see if that works but I'm not holding my breath
isamu
Here's a screenshot my mkv log using a (just flashed) fw 1.02MK.bin
edit: looks like file attachments are prohibited.
Here's what's in the log box:
____________________________________________________________________________________________________
MakeMKV v1.17.7 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
Downloading latest SDF to C:\Users\Administrator/.MakeMKV ...
DEBUG: Code 4279336995 at #RR.[3VW3f!jtf":121262877
Automatic SDF downloading is disabled or failed.
DEBUG: Code 152 at vtE<(>?]*E!<z7r!:213144911
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Backing up disc into folder "E:/UHD BD Rips with MKV/THE BIG BOSS UHD"
Downloading latest HK to C:\Users\Administrator/.MakeMKV ...
DEBUG: Code 0 at vtE<(>?]*E!<z7r!:29400163
Saved AACS dump file as C:\Users\Administrator/.MakeMKV/MKB20_v77_THE_BIG_BOSS_UHD_08EC.tgz
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721
DEBUG: Code 0 at 5/<7b82nbE+t^cNR#y]:121273319
DEBUG: Code 0 at N&3LdAG_F{9!Br@1WHcm:121265338
Backup failed
_____________________________________________________________________________________________________________
What does all this mean? Any ideas?
Backup failed
The firmware is not the issue. I dunno why people seem to keep changing the firmware cause they think that's the issue. IT IS NOT!!isamu wrote: Sun Jul 14, 2024 1:32 amThanks for your reply Billy. OK so first of all...Billycar11 wrote: Sun Jul 14, 2024 12:57 am Is makemkv integration enabled?
Select Open disc
Then play
YES
Select Open disc
Then play
Please let me know what else I should try this is driving me up the wall! I'll try Firmware DE_LG_WH16NS60-1.02MK.bin again and see if that works but I'm not holding my breath![]()
You need to sort out the issue why MakeMKV cannot decrypt a disc. If it can't decrypt the disc, it cannot be used as the on-the-fly decrypter to play UHD with VLC.
First of all, is your drive a newer one with SVC NS50 or is it an older NS40 from prior to 2016?
Have you ever been able to rip a UHD disc using this drive and MakeMKV?
isamu
Here's what's in the info pane:
OS device name: G:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: [redacted]
Highest AACS version: 81
Firmware version: 1.02
Disc Information
Label: THE BIG BOSS UHD
Timestamp: 2023-06-12 13:35:12
Protection: AACS2.0/C v77
Data capacity: 92.55 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Anything unusual?
OS device name: G:
Revision: 1.02
Disc Information
Number of layers: 3
Anything unusual?
That doesn't help us now. We need to know what it was prior to you flashing it. Try looking at the label sticker on top of the drive.isamu wrote: Sun Jul 14, 2024 1:56 am Here's what's in the info pane:
OS device name: G:
Revision: 1.02
Disc Information
Number of layers: 3
Anything unusual?
isamu
Hello Marty and thanks for the reply. It is this one...MartyMcNuts wrote: Sun Jul 14, 2024 1:55 amThe firmware is not the issue. I dunno why people seem to keep changing the firmware cause they think that's the issue. IT IS NOT!!isamu wrote: Sun Jul 14, 2024 1:32 amThanks for your reply Billy. OK so first of all...Billycar11 wrote: Sun Jul 14, 2024 12:57 am Is makemkv integration enabled?
Select Open disc
Then play
YES
Select Open disc
Then play
https://www.amazon.com/gp/product/B00E7 ... =UTF8&th=1
I looked at the disc drive itself before installing it and noticed it says manufactured in 2023, but on the website it says "Date first available July 28, 2013". So not sure what to go on here?
I have only had it for about 3 months and have never tried ripping anything with it before. How would I find out if it's the newer one with SVC NS50 or is it an older NS40 from prior to 2016?
isamu
I did a back dump of the original firmware and it is:MartyMcNuts wrote: Sun Jul 14, 2024 1:58 amThat doesn't help us now. We need to know what it was prior to you flashing it. Try looking at the label sticker on top of the drive.isamu wrote: Sun Jul 14, 2024 1:56 am Here's what's in the info pane:
OS device name: G:
Revision: 1.02
Disc Information
Number of layers: 3
Anything unusual?
HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_KLKNCPB5824
Let me know if you can find out with this info....otherwise I guess I have no choice but to see if I can pull the drive out if this doesn't help? Let me know.
this is your issueisamu wrote: Sun Jul 14, 2024 1:49 am Backing up disc into folder "E:/UHD BD Rips with MKV/THE BIG BOSS UHD"
your isp or firewall is blocking key downloads
change your dns
check your firewall for geo blocking russia
use a VPN and many different end points until it works
The drive appears to be a new one as you say, so don't worry about that. Yes, Billy is correct. As per your log, the HK downloads are failing. You need to resolve this issue before being able to rip/play UHD discs.Billycar11 wrote: Sun Jul 14, 2024 2:10 amthis is your issueisamu wrote: Sun Jul 14, 2024 1:49 am Backing up disc into folder "E:/UHD BD Rips with MKV/THE BIG BOSS UHD"
change your dns
isamu
Billy can you please tell me how to go about:Billycar11 wrote: Sun Jul 14, 2024 2:10 amthis is your issueisamu wrote: Sun Jul 14, 2024 1:49 am Backing up disc into folder "E:/UHD BD Rips with MKV/THE BIG BOSS UHD"
change your dns
Changing my DNS
Checking my firewall for Geo blocking Russia?
I already have a VPN although it wasn't turned on.
Thanks in advance.
isamu
OMG I'LL BE DARN IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I didn't have to change my DNS or mess with my firewall, all I had to do was enable my VPN!! I set it to Germany and voila it works!!!!!!!!!!!!!!!!!!!!!!!!!!
I admittedly haven't tried to rip the disc yet, only play it, but so far it's playing just fine! Thank you SO FUCKING MUCH @Marty and @Billycar for the suggestions and the help in resolving this issue.
Just a quick question for confirmation @ Marty.... firmware DE_LG_WH16NS60-1.02MK.bin *IS* the one I currently have installed. Is this the one you suggest for this particular drive for only playing movies via VLC?
isamu
Hmmm....OK seems the video does play for a little bit but then suddenly freezes after about 2 minutes in, while the audio continues to play. Any ideas what I can do to remedy this, or is VLC just a shitty player for UHDs?
Yes, that is the recommended firmware for your drive.isamu wrote: Sun Jul 14, 2024 2:33 am OMG I'LL BE DARN IT WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It is recommended not to play UHD discs. It's far better to rip them first then play the rip.
