Dump Submitted - Civil War
MKB20_v77_Civil_War_AEC4
Re: Dump Submitted - Civil War
The other Civil War thread: https://forum.makemkv.com/forum/viewtopic.php?f=12&t=34627
The implication being I should add my dump into his post? My assumption was to post it separately as to not get lost in the fray, but if that is the SOP, I'll abide.
Generally, one thread per movie is enough. Some movies end up needing quite a few different hashed keys, so if there is one thread per hashed key, we'd end up getting lost in a different way.
This is the response from MakeMKV on the new Civil War 4K bluray disc
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=62194E19F4EC)
Saved AACS dump file as C:\Users\xxxx/.MakeMKV/MKB20_v77_Civil_War_943A.tgz
If you haven't already, submit that dump through email.
Sent from my SM-S928U1 using Tapatalk
currently having the similar issue
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Saved AACS dump file as C:\Users\xxx/.MakeMKV/MKB20_v77_Civil_War_943A.tgz
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213131341
Amazon US failed to open (dump attached).
Is it working for anyone in the UK?
HayItzDatGuy
