Output folder same as source ?
psymeuh
Post by psymeuh » Mon Jul 01, 2024 8:43 am
Hey o/
Is there a way to set the default destination folder to be the same as source ?
Anyone ?
Re: Output folder same as source ?
Post by Woodstock » Mon Jul 01, 2024 4:37 pm
Generally, the "source" is a plastic disk... Why would you want to set the output to be a read-only place?
psymeuh
Post by psymeuh » Thu Jul 11, 2024 3:41 pm
My "source" is my NAS, I have 200+ ISO files to convert to MKV preserving their location.
Post by Woodstock » Thu Jul 11, 2024 4:47 pm
Preferences->Video, you can set the output destination. As "SemiAuto", you can set the directory to be where your ISO files are stored, but leave the option to create directories for each disk's contents.
I use "Z:" as the destination, and this offers to create (and does if I tell it to rip) "Z:\disk_name", where "disk_name" comes from the contents of the rip. It can be edited if MakeMKV grabbed the wrong name.
psymeuh
Post by psymeuh » Thu Jul 11, 2024 5:17 pm
I know that, but that's not what I need, my directory structure is more complex than that...
I need the MKV to be in the exact same folder as the ISO file
Post by Woodstock » Thu Jul 11, 2024 6:16 pm
Then you're stuck with waiting for Mike to say what's possible. Best I can determine, the program assumes that the source is separate, and not something you can jump around much to, so the output is more tied down. It's possible that you can do something with the command level (rather than the menu) though - which would make sense for batch processing.
Ezatoka
Post by Ezatoka » Thu Jul 11, 2024 8:01 pm
Try using the command line makemkvcon.exe / makemkvcon64.exe
