Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Tue Jul 09, 2024 9:29 pm
Koolbite wrote: Tue Jul 09, 2024 3:25 pm
Here is the MakeMKV window :
https://ibb.co/jHGN7BV
If you can help me through this process it would be much appreciated. i can pay you a little fee for this if it works.
I see and did you test it before you flashed it?
What is the build date on the drive?
How it it hooked up to the PC direct SATA or what model USB adapter?
You mean if i was using the drive before i flashed it ? Yes i had been extracting CDs and DVDs since i bought it in december 2021 until right before i flashed it.
I don't know where to find a build date. I don't see that information either on the packaging or the drive itself. But Like i said it was working until right before i flashed it so i think firware change is the cause and not the drive being too old (if that was the sens of your question).
It's an external model so i plug it through usb 3.0. Here is a capture of my device manager window : https://ibb.co/2c9Y41r (sorry it's in french but i think you still get the harware information)
Thanks !
Re: SDFtool Flasher
Koolbite wrote: Wed Jul 10, 2024 9:03 am You mean if i was using the drive before i flashed it ? Yes i had been extracting CDs and DVDs since i bought it in december 2021 until right before i flashed it.
Thanks !
just post the top label of the drive it has the build date
the device manager does not help me help you
but if it worked with this before then the adapter should be fine.
Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Wed Jul 10, 2024 9:39 am
Thanks !
Tell me if you have the information you're looking for there
https://ibb.co/xmS31Sw
https://ibb.co/nB99DW0
https://ibb.co/tBbB4Hy
Thank you !
Re: SDFtool Flasher
Koolbite wrote: Wed Jul 10, 2024 1:21 pm Tell me if you have the information you're looking for there
Thank you !
I meant inside of the drive but whatever.
Really last chance of it working is writing the bootloader too when you flash try that and flash to wh16ns60 1.02
If that don't work the drive is dead
Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Wed Jul 10, 2024 2:19 pm
Thank you !
What is wrting a bootloader ? I googled it but what are we trying to do ?
btw the drive is not working on any computer.
Thanks !
Re: SDFtool Flasher
Koolbite wrote: Wed Jul 10, 2024 6:34 pm
Thanks !
In the tool there is a check box I believe it says include bootloader check that box and select the WH16NS60 fw and flash that
Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Wed Jul 10, 2024 11:59 pm
Thanks !
I had tried that already. It's now dtetected as BD-RE__WH16NS60_1.02 but still won't reaad anything.
Re: SDFtool Flasher
Koolbite wrote: Sat Jul 13, 2024 10:20 am
Thanks !
yeah it dead then please only follow the guide not random youtube videos
Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Sat Jul 13, 2024 10:52 am
The video follows this guide though. i'm pretty sure the is a way to revive it but the time for me to figure it out, it's actually cheaper to buy a new one.
Re: SDFtool Flasher
Koolbite wrote: Sat Jul 13, 2024 11:10 am
the guide no where says to flash BU40N to your asus you said you followed the video and did that
my guide clearly says asus on any fw directly to 3.10mk
Koolbite
Re: SDFtool Flasher
Post by Koolbite »
Billycar11 wrote: Sat Jul 13, 2024 11:22 am
yes you're right i just followed the video (which says follow Marty's guide) and didn't read your guide or MArty's guide myself. the comments were all praising the tutorial and i had no idea this could result in this.
Kevin_28
Re: SDFtool Flasher
Post by Kevin_28 »
Hello folks,
Apologies if this has been asked and covered ad nauseum, but I am having an issue with crossflashing my LG BP50NB40 NB50 drive. I think I have made a mistake when I originally flashed my fw v1.0 to 1.03. Instead of using the marty version, I used the ones on the Ultimate UHD Drives Flashing Guide (viewtopic.php?f=16&t=19634) that goes to the google drive folder. I was able to flash to 1.03 using the write function on SDFtool Flasher (v1.3.5), however when trying to crossgrade to either the BP60NB10 or the BU40N version, it says, "Done successfully, please wait.", but I am unable to play any 4k disks and I don't see that version reflected on MakeMKV nor the SDFtool Flasher. MakeMKV provides me this info:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Highest AACS version: 60
Firmware version: 1.03
I tried to download the Marty versions of the bin files and write 1.03_mk to the drive (don't know if that worked at all) and crossflash it to the BU40N and BP60NB10 bin files but to no success. They all say it was successfully done but I am unable to paly anything other than blu rays. Any help would be greatly appreciated. Thank you so much.
Re: SDFtool Flasher
Kevin_28 wrote: Mon Jul 22, 2024 6:24 pm Hello folks,
Revision: 1.03
Serial number:
You need to use the recovery option for the crossflash. Follow the gif in the first post of this thread.
Kevin_28
Re: SDFtool Flasher
Post by Kevin_28 »
MartyMcNuts wrote: Mon Jul 22, 2024 10:31 pm You need to use the recovery option for the crossflash. Follow the gif in the first post of this thread.
Hi there! Thanks for responding and helping me out. I should have mentioned earlier in my initial post that I used write to update to 1.03 and recovery for the crossflash as per the instructions.
Re: SDFtool Flasher
Kevin_28 wrote: Tue Jul 23, 2024 12:43 am
So you're all good then?
