Aliens 4K (Ultimate Collector Edition)
Stevelois
Re: Aliens 4K (Ultimate Collector Edition)
Post by Stevelois » Sat Jun 29, 2024 3:05 am
Been away for a while.
With the third copy (returning the first two), I've been able to rip the disc without any issue. Even if the disk was looking super clean to the eye and play well in my Panasonic player. It really was something about the disk.
Post by Billycar11 » Sat Jun 29, 2024 4:26 am
try a pioneer drive you been through 3 sets of disc replace that junky asus from the first post
i have pioneers with old FW if you want one
Stevelois
Post by Stevelois » Mon Jul 01, 2024 3:42 am
The drive work well when the disks are ok.
I rip dozens and dozens of 4Ks disk without any issue, only sometime, there are some that are problematic and I post here as the last resort for a logical answer. The replacement disks habitually are fine so if it was the drive, I would get the same results from disk to disk which isn't the case at all.
I leave this post open to help others, my problem for that movie is resolve.
Post by Billycar11 » Mon Jul 01, 2024 12:50 pm
All I know is people with Asus/LG drives
Have to do a lot of exchanging compared to pioneers
Post by SamuriHL » Mon Jul 01, 2024 12:58 pm
Yea, I mean I have 2 pioneer drives and the last time I had to clean a disc or replace one is ummmmm, well it's been a while.
tbrady3742@aol.com
Post by tbrady3742@aol.com » Tue Jul 09, 2024 2:33 am
Yeah, I'm on my 3rd ASUS drive, if I had known about a good Pioneer drive, I would have gotten that one. So far this one hasn't been giving me any trouble but if it does, then I will get a Pioneer. What is a good one that you would recommend for blu-rays and 4Ks? I use MakeMKV and DVDfab for ripping.
Post by Billycar11 » Tue Jul 09, 2024 2:46 am
the s13UBK is what i recommend but remember you need to get one with old FW they can not be flashed at all.
for now i have them with old fw see below
Post by SamuriHL » Tue Jul 09, 2024 3:26 am
And DVDfab doesn't support pioneer at all at this point. They talked about adding it at one point but haven't so far. You can't go wrong with one of Billy's drives though. They are rock solid!
Sent from my SM-S928U1 using Tapatalk
Post by Billycar11 » Tue Jul 09, 2024 5:54 am
yeah said it in my head for the reply that they dont work for dvdfab for UHD but do for dvd and bluray but didnt make it to the written part thanks for clarifying that for them
tbrady3742@aol.com
Post by tbrady3742@aol.com » Wed Jul 10, 2024 2:29 am
Thanks for the help. That's good to know because I use DVDfab for blu-rays and dvds, makeMKV for 4Ks.
zzz00
Post by zzz00 » Tue Feb 18, 2025 2:42 am
I seem to also have an issue with this. Partway through 28249.8M if that helps. It just stops working without any errors. Just stops spinning and MakeMKV shows it continuing but with no data being added. Happened twice now and not sure what's going on. Any ideas other than returning and trying with a new disc?
Product: BD-RE BU40N
Disc Information
Label: ALIENS
Timestamp: 2024-02-13 19:20:43
Protection: AACS2.0/C v77
Data capacity: 85.60 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
EDIT: New disc worked. both says it was manufactured 2/13/25 so seems like they did not fix any QC issues they have with these. No scratches on either but one works and one doesn't
