MakeMKV asks me to update, but then says I'm already updated
I'm running v. 1.613 on Win 7 64 bit system and the program say to update to 1.164. I download it, but it won't install says it's already installed, strange. is 1.164 only for 32 bit machines? Should I uninstall and reinstall to get 1.164?
setarip_old
Re: MakeMKV asks me to update, but then says I'm already upd
Hi!
Is your problem possibly the result of trying to install, as you state 3 times, v.1.164 instead of v.1.6.14?
No, just a typo...
1.6.14 is what I've been tying to install.
- Contact:
MakeMKV installer should overwrite old install. Please try uninstalling and installing again.
