The Legends of Monkey
fredd123
Post by fredd123 » Mon Jul 08, 2024 2:45 am
Hi, I need help for the "The Legends of Monkey". It grey out when inserted it to the player, yet it works fine on TV. This 4 discs of Season1 and 2 are all the same they grey out.
Re: The Legends of Monkey
Post by Woodstock » Mon Jul 08, 2024 1:15 pm
In what program are they "greyed out"? MakeMKV will either open the disk, or say "No disk".
fredd123
Post by fredd123 » Tue Jul 09, 2024 3:35 pm
It appears on MakeMKV as proper disc, but within like 2 seconds spinning than it stop and greyed out. Also on the File explorer as well, it just shows the Disc ID but not accesible (greyed out).
fredd123
Post by fredd123 » Thu Jul 11, 2024 11:21 am
I found a solution for this. I run the DVD on my 8 yo laptop and it acceot it. Than I burn it using DVD SHRINK, than I took it back to PC and run the MakeMKV. Surprisingly it convert 1 DVD with 6 episodes in it - in just 30 seconds, speed of light so to speak.
Thanks you all for your time.
